okay, so last night I started cutting a 8' long piece of HDU "trim". It is two 2" thick pieces epoxied together. I have the stock aligned with the X axis. I roughed the stock along x axis and everything was fine. I then switched to my finish pass which I ran along the y axis. I am going to try to attach images of toolpath below.
So the problem was first noticed towards the end of the finish pass. At the beginning it was moving along just fine started at the top (z=4), rolled down the trim surface down to just about z=0, stepover y -0.100" then back up the surface to z=4, stepover y -.1", and so on down the length of the 8' stock. I walked into the other room preparing the next toolpaths, and when I came back in to the machine room it was cutting the same thing, still looked accurate, but after the stepover at z=4 and z=0 the tool would "lull" not move as quickly as it had when it started at the other end.
I felt like something had to be wrong, and I was really hoping it was something in the toolpath. Maybe there was something weird in my extruded surface that was causing problems on that end, that seemed unlikely it just had a hardware feel to it, but it was cutting the right shape, and I would have expected something to cut incorrectly with a feedrate change like that that wasn't intentional.
I finished one of the two pieces like that I had to cut. I left last night thinking I needed sleep and I would have to finish this evening with the other part after the day job. but I woke up this morning concerned, and fully aware that the day job is waiting on me to finish these parts and get the molds into production so I decided to start back up early this am. I started back up with roughing passes and prepared a finish pass that added loops to the stepover thinking that maybe the .100" stepover at 180ipm was maybe causing the problem.
Well I didn't get to the finish pass because 95% of the way into the roughing the tool stopped and said "TOOL STOP BUTTON IS ON". I certainly did not hit the E stop. Then I thought that I think this is like if you were to plunge the tool and it lost position. I have only done that once or twice and I think I just restarted SB control and hit reset and I was back in business. So I closed SB control and when I hit reset it didn't sound or feel right. A double-click in the relay and it wouldn't catch. VFD started to power up then back off again. reminded me of trying to reset a breaker that was bad.
The tool was not under a significant load when it stopped. 1/2" endmill .75" depth of cut engaged 45% in HDU. So I am guessing this is the sign of something more serious. Bad driver? bad motor? something in the closed-loop stepper system?
I am all strung out on stress and lack of sleep, and as much as I need to get these parts cut I want to let some of the community wisdom help guide me in what to do next. I am going to send this to SB support as well.
well nevermind on the pics, I guess I cannot figure out how to attach. It was just screen shots from CAM software.
Thanks in advance for any help you guys can give.
