Results 1 to 10 of 15
Thread: New Dual Pump Vacuum System
Hybrid View
    Oct 2009
    KenCraft Co Inc, Toledo Ohio
    Brady.
    I've done a lot of onion skin cutting with maybe 80% satisfaction on results. You mentioned above "ut 90% through all of your parts first, then go back full depth with minimal cutter to material force to shave off that little bit" Can you explain minimal cutter force a bit more.
    Tracy Spitulski
    KenCraft Co Inc.
    PRSa 6096
    www.kencraftcompany.com
    Hardwood Lumber, Custom Millwork
    Dust Collector Fittings
    Tracy,
    If you don't break through the onion skin, you won't lose suction. The idea is to let vacuum hold down your parts while cutting aggressively (tool pushing back against material with high force) - without breaking through the skin. Then when all of the parts are cut, say .7" deep in .75" thick material, come back and make the tool go .75" deep, cutting all the way through your parts - now breaking through the skin and inevitably letting the vacuum leak through the kerf. Since the tool is only cutting .05" off of the part on the last pass, there is very little force being exerted, and therefore, the parts shouldn't move even with low vac showing on the guage.
    There are other things that come into play depending on what you are cutting, how grabby the material is, how high your chipload is and the geometry of the tool being used to cut the parts. If your parts are still moving with good vacuum numbers and onion-skinning, you may want to look into a compression spiral, or even straight flute tool. In more extreme cases, a downcut can be used, at the expense of blowing out the bottom edge and packing the kerf with chips (straight will pack them also - sometimes to your advantage, such as with plastics.)
    Does this make sense?
    Feb 2015
    NC, USA
    Brady,
    Which pen are you using to make the control board?
    And where did you get it. I can find thick line but that looks pretty thin.
    Wigitworks with Micro Sharpie. Now unobtanium. Not WW's fault. Sharpie stopped making them.
    I have another setup under development to fill the void for when these dry out. Something completely rebuildable and adjustable.
    Feb 2015
    NC, USA
    Got it thanks.
  1. Vacuum Pump
    By dmidkiff in forum ShopBotter Message Board
    Last Post: 05-15-2014, 08:29 AM
  2. Vacuum pump
    By mars in forum ShopBot Accessories
    Last Post: 09-08-2013, 04:49 PM
  3. Vacuum pump
    By tomahack in forum Archives2008
    Last Post: 11-28-2008, 03:40 PM
  4. Vacuum Pump
    By harve in forum Archives2008
    Last Post: 09-11-2008, 01:51 PM
  5. Vacuum Pump
    By frank_hav in forum Archives2007
    Last Post: 03-27-2007, 12:53 PM
