hey all,
i'm sure these must have been addressed before but apparently my search-fu is not up to the task, so if anyone can point me to a thread that would be fantastic.
I have a prs standard from 2009, and outside of operator error it's run fine since it arrived. Lately I have two issues, one just weird and the other a real fabrication hiccup:
1) as i load nearly every part file, i get a "pause in file. continue?" dialog box after the machine starts up and immediately pauses. I click through and everything then runs fine. I've looked in the spb and sure enough there's a pause line i don't remember asking for but which keeps being inserted... any thoughts?
2) Recently i've run a couple of projects requiring matching inside and outside cuts, so that a positive shape should fit snugly into a negative space (cut from matching vectors with differing tool path assignments). Instead of a nice fit i'm getting no fit, with weird misalignments around the shape. I've changed bits and altered feed rates and can't get rid of the asymmetry. Are there unit value settings that can affect this?
thanks!
andy
