Results 1 to 10 of 17
Thread: 22.5 degree cuts?
    Oct 2012
    Boulder, CO
    Question 22.5 degree cuts?
    I need to join two pieces at a 45 degree angle, and one of them is too big (and oddly shaped) to put on my table saw. Has anyone used 22.5 degree V bits to cut matching pieces like this? My material is .75" thick, so I'd need a bit that will allow multiple passes to get the total depth.
    thanks for any info,
    John
    John...
    I haven't specifically used a 22.5° bit to make a joint, but I routinely use a 45° bit to make boxes with a waterfall grain pattern. My joints have all been les than 16" in length, but there's no reason it wont work on a larger scale. I've found that I have to have a pristine spoil board under the joint to support the veneer while being cut, I can however make extended runs of the same project with the same spoil board surface. Attempts to make a "fold up" joint where the last little bit of the bottom is left un cut, have been disappointing...
    Yes I have.
    Amana makes a good one that is an accurate 22.5 degrees as I recall.
    cnc routing, portland or
    Yes I have.
    it sucks and I don't think they make it anymore. I bought one for this job and the cut was off 1.5 or 2 degrees I can't remember now for sure. the carbide knife was off. Plus there is no way to get anotehr knife back in accuratly there is nothing to index against it. When I called amana they said they had only sold 4 or 5 to dealers
    I had bought one and used it years ago for some octagon shaped porthole frames and it worked well, but it wasn't an insert type. I could be mistaken about the brand but I thought it was theirs.
    Jun 2007
    Hampton Roads, VA
    I have one from WhiteSide I used it for a flag box. I worked well. I'll walk out to the shop and see if I can find the package.
    Jun 2007
    Hampton Roads, VA
    Quote Originally Posted by khaos View Post
    OK, it is:
    Chamfer bit
    22-1/2 degree angle
    1/2 shank
    7/8 cutting height
    15/16 cutting length
    2-3/4 overall length
    part#2307
    I paid $31 for mine this year
    once I had the part # it was easier to find here.
    hth
    Oct 2012
    Boulder, CO
    Beginner questions time:
    I need the cut an angle on the entire thickness. Would I cut my part with an end mill on the shopbot and then use a hand router to go back over it for the angle?
    I can't use the bearing with my thru cut, so I 'd need to use another means to keep the hand router on path.
    Am I missing anything?
    thanks
    this was the insert. it was a joke really lucky the client bought it not me.
    John...
    No you aren't missing anything. A piloted bit would not work. If you can't find a bit intended to be run on a CNC machine, you might have to clamp a straight edge to your material and use the bearing bit in a hand held router...
    When I tried to search for a bit, I found horrible inconsistency in nomenclature... A bit that cuts a 22.5 angle should be called by its included angle or a 45° bit. That made for many false searches!
  1. 90 Degree V Bit
    By jim_vv in forum Sign Making
    Last Post: 12-02-2013, 01:29 PM
  2. Need help finding a 25 degree bit.
    Last Post: 05-27-2011, 06:02 AM
  3. degree settinghead
    By kevin in forum Indexer
    Last Post: 01-26-2011, 08:24 AM
  4. 67.5 degree bit
    By mgilley in forum ShopBotter Message Board
    Last Post: 07-30-2010, 05:52 PM
  5. 15 degree or 75 degree bit?
    Last Post: 07-10-2009, 11:37 PM
