Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 22.5 degree cuts?
    Oct 2012
    Boulder, CO
    http://www.amanatool.com/bits-fv/rc1045.html
    RC-1045 looks to be what I need.
    thanks everyone!
    I would listen to Steve-He didn't like the Amana insert and he is highly skilled.
    I would listen to Joe-The Whiteside worked well and he is highly skilled.
    I checked my cabinet after work-It's the Whiteside I used, and not an Amana.
    If you buy a bunch of Whitesides from Ballew Tool you get a discount. Good customer service and usually same day shipping.
    Oct 2012
    Boulder, CO
    I listen, really I do. And I buy Whiteside almost exclusively. But I do not see a Whiteside bit that does what I need, and I need this job completed in a timely manner. So I will start with the Amana and see if it does the small quantity I need in the short term. Expensive, yes, I hope it works.
    cnc routing, portland or
    at the time the insert was all I could find.
    If you are crafty you can put that angle on your material with just an end mill, and creative toolpathing & offsetting vectors. It won't be a smooth as an angled bit, but a few swipes with sandpaper or a scraper and you're there. So if the Amana insert doesn't work out - you have an alternative.
    Please report back and let us know how that bit works for you. I have a few of the larger angle Amana insert bits & they are awesome.
  6. #16
    this job does not even require a cnc router (gasp blasphemy) just cut the angle on a block of material on the tablesaw then double side tape or clamp or nail the part to the block and run it through the tablesaw.
  7. #17
    Oct 2012
    Boulder, CO
    Quote Originally Posted by knight_toolworks View Post
    If my part was small enough, I'd do it on my tablesaw like all the other angles I make. But this is a 60" by 30" piece of 2-sided melamine and the section with the 22.5 degree cut is at 75 degrees from the only straight side I have. Too many issues for me to expect myself to do it properly on the tablesaw. At least I get to try something new, right?
  1. 90 Degree V Bit
    By jim_vv in forum Sign Making
    Last Post: 12-02-2013, 01:29 PM
  2. Need help finding a 25 degree bit.
    Last Post: 05-27-2011, 06:02 AM
  3. degree settinghead
    By kevin in forum Indexer
    Last Post: 01-26-2011, 08:24 AM
  4. 67.5 degree bit
    By mgilley in forum ShopBotter Message Board
    Last Post: 07-30-2010, 05:52 PM
  5. 15 degree or 75 degree bit?
    Last Post: 07-10-2009, 11:37 PM
