Results 1 to 7 of 7
Thread: Collet Bearing Nuts - Good/bad/tips?
    Feb 2004
    , Cheltenham
    Default Collet Bearing Nuts - Good/bad/tips?
    Has anyone with a spindle tried bearing collet locknuts on their ER25 spindle? I have recently gone over to using a torque wrench and am somewhat amazed at how rarely cutters fell out when I was just using the 2 short spanners (I probably never used much over 25ftlb). I wondered if bearing nuts would help - given their reported improvements, would a lower torque setting be valid?
    Allbest,
    R.
    Sep 2009
    Surrey, UK
    Are you having issues with bits falling out when they collet is done up?
    That's more likely to be a sign of the collet being worn out or choked with dust I would think.
    I've never had a bit fall out but I alternate three collets making sure that they are cleaned thoroughly between each use and I change them once a year.
    Mar 2009
    Pope Valley CA
    I'm with Adrian on this - I've never even had a bit slip, that I'm aware of, let alone fall out. I clean my collets after each run, and also alternate them. One thing I'm sure you are aware of, but is good for newcomers to remember, is to snap the nut onto the collet correctly, or it will never tighten properly.
    What spindle do you have, and which nut? The mini ER25 nuts are only supposed to be torqued to ~25ft/lbs., while the standards go up to ~70-80, if I remember correctly. You will also damage your collets by over-tightening them.
    Bearing nuts will improve static stiffness and greatly improve damping, which can suppress chatter, but I simply don't think they would make that much difference in wood or soft materials.
    If you decide to give them a try, be sure to let us know the outcome!
    Ron Sloan
    Feb 2004
    , Cheltenham
    Hi,
    No I change collets quite often - and my usage at my own shop is very low - I would say at least every 2 months of low production level usage. The collets are the large ones, not the mini castles. We tried torque wrenching when 170mm long x 16mm dia upcut spiral cutters started escaping at our project workshop. In my workshop I now have the torque wrench set to around 40 ft lbs (I use the torque to set it, but can just use the smaller spanner to undo), and it works well - at the project we run at around 65, or a little more for the big cutters.
    We plan to try the bearing nuts and see how it goes.
    R.
    Feb 2004
    , Cheltenham
    Ps: at the project the operator is almost obsessive about cleanliness...
    May 2008
    Port Orange Florida
    Do you have the collet snapped into the nut.
    Winter Park FL
    Not only is it important to clean the collet and nut but the inside of the spindle where they fit. I also spray my collet and nut with T-9.
  1. Is this Shars ER 20 Collet set good for Desktop MAX spindle?
    By carolinasmith in forum ShopBotter Message Board
    Last Post: 09-13-2016, 06:30 PM
  2. er 20 collet nuts fine thread.
    By knight_toolworks in forum For Sale/Wanted - ShopBot-related items only
    Last Post: 06-17-2016, 10:30 AM
  3. fan type collet nuts for the ER25?
    By Ajcoholic in forum ShopBotter Message Board
    Last Post: 01-25-2014, 01:07 PM
  4. A simple question: Colombo replacement collet nuts
    By brian_h in forum ShopBotter Message Board
    Last Post: 08-14-2009, 09:16 AM
  5. Er 25 nuts are nto all of the same.
    By knight_toolworks in forum Archives2008
    Last Post: 04-01-2008, 07:21 PM
