Steve, I very much agree with Adrian on you maybe pushing the envelope to much. We are doing prototypes that are being passed around New England so quality is most important and finishing is very time consuming compared to cutting. I can run faster than I do, but I'll have to run the piece twice because of the finish and bit deflection and I'd rather run it once slow than twice fast. Always check your bit temp after a new wood or cut(should be room temp). Mainly cutting sugar maple ,but out of our 20 bits very few like faster than 1.7 IPS and most do best in the 1.1-1.5 IPS range(most of our bits smaller than .2") and none like faster than 16K. Fastest is 3 IPS for surfacing routine at 12K. Run the same routine again and you can hear how much bit deflection you are getting. Again watch your depth of cut.
When running a new wood or new bit that is significantly different than anything you've done before and you're worried, I've found the people here on the forum very helpful(do a search first, as I've found most of my questions have already been covered-A google search is sometimes more helpful finding stuff than a forum search). At some point you WILL need the people here. I've seen 2 guys stall my Unisaw(hop hornbeam slab), that doesn't make it a bad machine. I do recommend you lose the gwizard for a couple months. I hope any of this was helpful, I ramble, Brady is succinct and VERY pertinent, Different styles. scott
