I used this technique successfully to build a bunch of box beams for a local restaurant/diner. works great. all done with a series of rectangles in vcarve pro.
thanks,
Brian
http://http://www.youtube.com/watch?v=PBXvBKCW3ao
thanks,
Brian
Brian…
I also use this method. It makes more accurate miters than I can cut on the table saw. Attached are some urns I make like this and a hex box made with a 60° bit… V carving and the miter angles. The 60° one wasn’t as accurate as I’ve become used to with the 90°one.
Brian your link does not work for me in chrome. What is the title of the video?
Nevermind i see what the problem was, you have 2 http;'s
Words of Wisdom:
Steve i sent you an email
10 minute limit
Words of Wisdom:
That is very cool.
Brian,
I am guessing you have a vacuum hold down table?
Was the box the actual finished size of the project?
Very nice, thanks for sharing
Life is like a project you continue to work on until it's finished.
Never start a project you don't intend to finish!
Are you using miter fold tape for the boxes??
George…
I use blue masking on the miters when gluing… Is there a specific “miter fold tape” that I’m not aware of?
I'm assuming you zero off the table. How much material do you leave uncut to hold the corners together?
This is where the miter fold tape comes in handy. Put the tape on the bottom of the board to be cut. Miter out box take off machine and glue.
