I have seen people asking about what kind of bench/table to put the Desktop on. I would like to relate my story -- even though it is not yet complete. I have mostly built a platform for my Shopbot Desktop from the crate that it arrived in. The top and sides come apart pretty easily. The hardest part thus far has been removing the six 4x4 "feet" on the bottom. I decided that I wanted it to be slightly less long than it was on the longest edge so I cut 7-3/4" off of the length and repositioned the 1x4s and the one 2x4 on the bottom. I re-assembled the bottom (now on the top) and sides all with their 1x4s & 2x4s on the inside. I then added some 2x4 framing on the inside as I want to put some drawers on the front. I also cut the opening on the front and back to allow for the drawers on the front and a door on the back. Then I took the former top and doubled-up the top of the bench -- again with the 1x4 material down in this case. I put two coats of enamel (one medium can was enough) and the width is just right for the desktop. When using, you still have to be mindful of the moving gantry on either side and the bottom; but it turns out to be very stable....
I have left to adjust the rails for the drawers, make the top drawer which is intended to be a router bits and misc shallow drawer, make the bottom drawer which will be for hold-down jigs and such, and setup the back door.
Just thought I would share.... Happy fabricating!!!!
