Results 1 to 10 of 12
Thread: Electrical feed to machine
Hybrid View
    Jan 2016
    Phoenix Arizona
    Quote Originally Posted by Rob Gunn View Post
    Randy, I ran a 50amp 220V drop from the ceiling and then mounted a circuit breaker box directly on my Shopbot frame. Doing this now gives me the option to run separate 110v to the Shopbot control box, router motor, and dust vac, also a 220v to a table vac. all from the one breaker box mounted directly to the Shopbot frame. I like this setup because now I only have one power cord going to the machine, rather than 4 separate cords running everywhere.
    Does anyone know if I can do similar if my spindle is 3 phase? Right now the electrician is planning on mounting a 3-phase 208v and a 1-phase 120 volt circuit either on the wall or overhead. But I love the idea of having just one power cord to the machine, and a vac hose, and an air supply hose of course. But still, that would be a cleaner install.
    Jan 2011
    Buchanan Michigan
    Simply ask your electrician if it can be done. I see no reason that it couldn't. One 3 phase drop to the machine base and then split that out to what is needed for the spindle, router, vacuum and whatever else you have there. It may require more than one circuit box / disconnect box and a transformer but it could be done. Let us know how it goes for you.
  1. Electrical problem
    By sawkerf in forum ShopBotter Message Board
    Last Post: 07-11-2015, 10:07 PM
  2. electrical
    By coach in forum ShopBotter Message Board
    Last Post: 03-27-2012, 10:50 PM
  3. Replies: 21
    Last Post: 06-20-2008, 10:02 AM
  4. Electrical hookup ?
    By dubliner in forum Archives2007
    Last Post: 07-26-2007, 10:28 PM
  5. Electrical use
    By steve_fedor in forum Archives2007
    Last Post: 03-27-2007, 10:45 AM
