I have been gluing and machining trying to build a vac press,
bit of trouble getting the vinyl but it will come ,the vinyl will
be held in the maple frame
and the frame will be clamped or latched
to the mdf table with an oring for a seal.(between the fram end the table)
Have a small 1/3 hp vac pump to connect up
The frame is also hinged so you can open it and place your veneer and the panel
you are veneering to
http://youtu.be/i3dawJZJo4c part 1 building a vac press
