Results 1 to 5 of 5
Thread: Chatter
    Aug 2008
    Plympton MA
    Default Chatter
    It's not bad, but I am noticing some chatter along the edge of my parts (3/4" melamine cut with a 3/8" compression bit). It just appears to be happening just along the X axis, the Y seems to be fine. I can feel some vibration on the gantry when it's traveling along the X axis. I don't think it's material/bit related, as I can feel it when the bit is under virtually no load.
    I'm guessing it's either loose or worn pinions, but thought I'd check here before I started pulling things apart.
    Nat Wheatley
    Plymouth Custom Closets
    www.plymouthcustomclosets.com
    Mar 2005
    Cabinets Plus of Augusta, Hephzibah Ga 30815
    What does the cut quality look like on the waste side of the material ? Maybe a change in cut direction will help?
    Aug 2008
    Plympton MA
    Hi,
    I'm seeing the same effect on the waste side.
    Forgot to mention that its a PRS Alpha 60x96.
    Nat Wheatley
    Quote Originally Posted by nat_wheatley View Post
    PRS/PRT - worn pinions & v-roller lash on YZ (PRS) or Y and Z (PRT, incl t-rail)
    PRT - check rails for burrs. File (by hand only) base of rail pyramid, polish with sandpaper and scotch pad.
    Aug 2008
    Plympton MA
    Thanks Brady. New pinions ordered...
    Nat Wheatley
  1. Chatter please help!
    By Initial Sound, LLC in forum Troubleshooting
    Last Post: 10-29-2015, 03:55 AM
  2. Got Chatter?
    By propellers in forum Assembly & Maintenance
    Last Post: 03-25-2014, 10:39 AM
  3. Chatter in 1/4 MDF
    By richard862 in forum Techniques for Cutting, Drilling, Machining
    Last Post: 05-30-2012, 07:23 PM
  4. Edge Chatter 2
    By frogwood in forum Techniques for Cutting, Drilling, Machining
    Last Post: 11-04-2011, 08:06 AM
  5. Chatter
    By rockbat@msn.com in forum Archives2003
    Last Post: 12-02-2003, 07:35 AM
