Results 1 to 10 of 11
Thread: Edge Lighting question
    Nov 2013
    Big Rapids, MI
    Default Edge Lighting question
    When you use LED edge lighting, are you grooving the edge of the plexi? Do you polish the edge? I am looking for the best light transmission I can get and if someone has already did the experiments to figure out the best way, I would like to hear your results.
    Norman, Ok
    Brian,
    You might search on the SB Forum on the method I used to make this set of letters.
    Jun 2011
    Melbourne, Australia
    Brian its really super easy to edge light. Just flame polish the edge using Map Gas. Don't be frightened by the 3,600F temperature warning on the bottle. The trick is to keep moving. Sawn edges come up great. Lots of demos on U-Tube.
    2.2 HSD Spindle
    Aspire 9.5
    6" ShopBot Indexer
    Apr 2011
    Stamford, NY
    Yes, Polish the edge that receives the LED.
    I don't always indulge in evil scientific research...but when i do. I make the parts on a ShopBot.
    Randy, any more info about that pic? Has anybody ever laminated and carved old cd's and carved and lit?
    Scott P.
    2013 Desktop/spindle/VCP 10
    Norman, Ok
    Naw, I'm telling everyone the idea of flaming, or torching the edge of plex isn't right. The way it's done by ALL Plexiglas manufacturers I've visited is by buffing.
    You start out with 240p going down to 600p. From there it's a quick buff with your soft rotary pad.
    I'd like to see everyone to pull out a torch and ruin some plex in order to find out how it doesn't work. That's a Tin Horn trick used on newbees.
    Jun 2004
    Springfield Mo
    Default edges
    I guess I will agree with the fellow with 2,252 posts...
    Apr 2011
    Stamford, NY
    [QUOTE=scottp55;158406]Randy, any more info about that pic? Has anybody ever laminated and carved old cd's and carved and lit?[/QUOTE
    The sign was 4ft x 12 ft approx 1" thick polycast acrylic internally lit by LED strips. There was a 1/8" thick maple veneer applied with black silicone as an adhesive. There's a special treatment we used when i worked there to "stabilize" the veneer and i am still bound to keep my mouth shut about it, Heh.
    Apr 2011
    Stamford, NY
    More acrylic and LED work i've been doing at my current place of employment.
    Thanks Randy, the visual effect was throwing me.
    Scott P.
  1. Sign lighting
    By brian in forum Sign Making
    Last Post: 05-09-2015, 02:27 PM
  2. LED Lighting
    By barrowj in forum ShopBotter Message Board
    Last Post: 10-13-2014, 02:14 PM
  3. LED task lighting for my PRT
    By br928 in forum ShopBot Accessories
    Last Post: 03-11-2014, 12:18 AM
  4. Gator foam clean edge cuts question
    By jhicks in forum Archives2007
    Last Post: 10-07-2007, 10:04 AM
  5. Lighting
    By andre in forum Archives2007
    Last Post: 08-16-2007, 02:57 PM
