Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 145
Thread: Bot up and runnig
    Feb 2013
    River Fall WI
    Default Bot up and runnig
    After a lot of fund raising and crazy problems we are up and running thanks to my woods class and Scott Worden
    Here are some pictures.
    Getting Power
    Assembling the table
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    Feb 2013
    River Fall WI
    More pictures.
    Making of vac table with two fein vacs
    Remade Jim Stoddart's vac box to fit the new fein vac III
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Feb 2013
    River Fall WI
    Little more.
    First kid made project for our local Baseball team.
    More to come....
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Thanks for all the pics Kyle, helps me understand the full size better.
    Scott Plaisted
    2013 Desktop/spindle/VCP 9
    Feb 2013
    River Fall WI
    Trying to make it like Alison Stoddart's post but I think his is way to good and clean to beat.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Feb 2013
    River Fall WI
    First production run, props for a dance class that does free Zumba for our PE class.
    Everything cut great but the bit slipped and the table will look a little fancy for a while (last picture is the table 3/16" deep).
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Well Kyle-They look great and now you learned to crank down on the wrenches when tightening your bit! I make it a rule to set the wrenches so I can squeeze them together with one hand so I get a strong grip and don't waste half my strength pushing against the axis and possibly screwing up my x or y location.
    (A day without learning something is a wasted day )
    Jun 2004
    Springfield Mo
    Default wrenches
    Shop seems to lack dust...
    Tie your wrenches together so you can lose them both at the same time.
    As above, wrenches should be used at a small angle and squeezed together (like a scissors) to change bits.
    Feb 2013
    River Fall WI
    The bit was tight but it was not high enough up in the spindle.
    It was the first time I had a student do it. (guess I need to watch better).
    Will be posting all the good and the bad.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Jun 2007
    Hampton Roads, VA
    Maybe if you got some gun bluing and dip the bits' shanks to the proper depth. Then you could have a teaching element and a visual cue to the proper depth.
    No blue below, good to go. Or something. And the kids can also self monitor each other.
