If I dont know a specific line number how would you do this?
You don't...you're screwed unless you know what line (or close to it) that it stops, and the basic location your bit is at when it stops.
If you do, then you can use the GO TO command insert the line number but you MUST have your bit close to the location. If you take it back to 0,0 and try that it will slice across your material and ruin it.
(Unless they have changed that)
When i used to get stops in my files i used to take notes by writing down line numbers every so often taking note of where the bit was. It has been so many years since that has happened to me i don't think about it anymore.
If you are continuing to have issues you might want to go back to an earlier version.
Words of Wisdom:
