While investigating laser equipment I stumbled on a few interesting things.
1 is what universal laser calls their powder fill technique for signs.
In general we're always looking for something new or better for finishing and these are some I thought were interesting for metalic gold, exotic pearlesence, and fill finishing
The Universal site says
Apply a matte black powder coat paint fill into the engraved areas of the wood with a paint brush as shown in Graphic 2.
Note: Powder coat paint is a dry paint powder made from finely ground solid resins. The natural oils in wood allow the powder to adhere without the need for any further treatment.
Note: You can get matte black powder coat paint from most paint manufacture’s or online from Harbor Freight at www.harborfreight.com/.
3.2: Wipe away any excess powder from the plaque with a cloth. Done!
When you see the photos it looks great but the question is how does the powder coat adhere inside the engraved areas? Says naturally sticks to natural wood oils? HUMMM??? I have a call into them but thought it would be a great V carve or recessed letter technique IF it really works.
2nd is another product called "RUB & Buff" for fill and wipe on glass signs. Shows GOLD and other metalic finishes and always on the look out for a gold leaf alternative.
site says Made from imported carnauba waxes, fine metallic powders, and select pigments, Rub 'n Buff gives almost any surface a new look in minutes. This unique blend gives objects decorated with Rub 'n Buff a finish that no paint can duplicate. It can be applied to any clean, dry surface as well as over previously painted surfaces. One 1/2 oz. tube covers up to 20 square feet.
It's easy to apply. Just rub onto any surface with finger or soft cloth, then buff to a lustrous finish. Rub 'n Buff is ideal for picture frames, stenciling, faux finishing, antiquing, home decor, restoration, and crafts
Check it out at http://www.bigceramicstore.com/Suppl...s/RubnBuff.htm
or many other art supply sites
Finally I've also seen and heard about this pearl Ex finish which says
http://www.jacquardproducts.com/products/pearlex/
Non-toxic, powdered pigments that exhibit extreme colorfastness and stability. They are ideal for interior, exterior and archival applications, and can be incorporated into nearly every art process. Pearl Ex pigments can be mixed into any viscous medium including all paints, varnish, airbrush paints, polymer clay, etc. They can also be applied dry to wood, ceramics, paper, wax, or any porous surface. Neutral pH makes these excellent for stamping or embossing. Temperature resistance allows them to be fired in a kiln up to 600 degrees.
Use Pearl Ex Powedered Pigments to simulate metallic sheens, shimmering pearlescents, leather, antique metal, raku pottery, hammered copper, and more.
