Results 1 to 10 of 12
Thread: My first aluminum 3D cut
    Mar 2008
    Columbus, Oh
    Default My first aluminum 3D cut
    Hello all,
    I have wanted to make a 3D aluminum cut for a long time. I just could not wrap my brain around pass depth's, cut speeds, and cooling. But I was very conservative and it worked out.
    Details:
    The Items:
    1. I am creating a Blue Moon kegorator for my home and I have wanted these for the sides for some time.
    2. The block is 6061 aluminum .75"x22"x25".
    Design:
    1. Aspire was used to turn the 2D object into the 3D object.
    The Cutting Process:
    1. I used a .25 end mill upcut bit for the 3D roughing. Cut depth was .004/pass, spindle speed was 9,000rpm, and feed rate was 2" per sec. Clearance was .004 and .1" for the outside border.
    2. A .25 ball nose was used for 3D finishing. Cut speed was 2" per second and I used a 4% overlap.
    3. WD40 was used as a coolant and you can see my clay wall that contained the liquid from spilling. A gallon of WD40 was $16, and I used it as needed.
    Mar 2008
    Columbus, Oh
    Here are some final photos.
    The small tabs are still attached. The next step is to encase it in cherry that has a thin boards and an inset on the back side for blue led's to be hidden by.
    Jun 2007
    , Cross Junction VA
    Impressive, Ben. I keep thinking I'll try aluminum some time, but seems like every project I do leads to ten more. It's still on my "to do" list
    Mar 2008
    Columbus, Oh
    Here is the Cherry holders. I need to get the led's installed to see if it works as intended.
    Mar 2008
    Columbus, Oh
    There must be an easier way to upload with an iPhone.
    Mar 2008
    Columbus, Oh
    Two more pics.....
    Mar 2008
    Columbus, Oh
    Last photo.
    Feb 2008
    Nice job and my favorite beer.
    WWW.MillerMarineProducts.com
    Proto Trak DPM CNC Bed Mill
    Brand X Industrial router
    Sharp SVL-2416SE-M VMC
    Mar 2008
    Columbus, Oh
    Thanks! I'm a big fan as well. I put in the LED's to see if I had enough overlap to avoid seeing them. It worked out quite well. Next is the lettering.
    Mar 2008
    Columbus, Oh
    Here are the 3D corian letters.
  1. 3D aluminum
    By john_l in forum ShopBotter Message Board
    Last Post: 12-03-2009, 05:00 AM
  2. Aluminum
    By coach in forum ShopBotter Message Board
    Last Post: 05-18-2009, 06:43 AM
  3. Aluminum 3D?
    By applik in forum Archive2008
    Last Post: 10-23-2008, 02:03 PM
  4. 3/8 aluminum
    By magic in forum Archive2008
    Last Post: 10-06-2008, 07:52 PM
  5. Aluminum
    By newton_c in forum Archives2007
    Last Post: 10-10-2007, 12:12 PM
