Results 1 to 7 of 7
Thread: Maxing out Z axis....
    Sep 2013
    Monroeville PA
    Default Maxing out Z axis....
    I'm trying to route slots the length of 4x4 posts for some installs. The issue is when zeroing to the plate, I only have about half an inch before the dust collection hits the gantry and it tool stops.
    There has to be a simple way of doing this that I'm not figuring out. Any suggestions?
    Sep 2008
    change safe z height
    Vector Studio 22
    Sep 2013
    Monroeville PA
    Tried that. Changed it to .5, it still hit because the zero routine goes higher regardless. Should I just bag the zero plate, put the bit on the 4x4, tell it that is zero and proceed? If these end up .49 or .55 deep, it's not critical.
    Sep 2008
    change safe z height in z zero routine or z zero off table
    Vector Studio 22
    Mar 2005
    Winchester Va
    Quote Originally Posted by gc3 View Post
    ^^^^ This^^^
    I have a project where I only have .200" above the part.
    I had to beat through the ZZero file and change it to .100"
    Jul 2005
    Brookline, New Hampshire
    Matt,
    Like Gene said, I'd z zero off the table.
    There may be another problem. Check your Z travel to make sure you can raise the bottom of the collet to at least 7 1/4 inches. That's 3 5/8 of exposed bit and another 3 5/8 to clear the material.
    Paul Z
    Mar 2011
    Marietta, Ga.
    You can leave your bit loose in the collet and well up the shank. Then move over your work and loosen the collet nut until the bit drops to the work and zero your Z. Then snug your collet and raise slightly and move away and finish tightening and then go from there...joe
  1. cutting a wave shape in the z axis along x axis?
    By sidofengland in forum ShopBotter Message Board
    Last Post: 09-02-2014, 05:20 PM
  2. switching Y axis onto A axis, How?
    By Fixed4that in forum Indexer
    Last Post: 10-22-2010, 05:15 PM
  3. Half table for 3 axis, half for 5 axis?
    By nodnerb in forum Table
    Last Post: 10-05-2007, 10:57 AM
  4. Replies: 22
    Last Post: 12-08-2004, 11:10 PM
  5. Setting Y-axis square to X-axis
    By Gerald D in forum Archives2003
    Last Post: 11-23-2003, 12:41 AM
