Results 1 to 5 of 5
Thread: Indexer B moves are doubled.
    Dec 2005
    Lexington, TN
    Default Indexer B moves are doubled.
    Good morning all,
    I'm trying to set up an indexer. I have a PRT Bot running 3.4.27 software. When I got the Bot, I bought an extra VEXTA A6497-9412KTG motor which I would like to use on the indexer direct until I can get pulleys and belts. The current VU are X/Y-733.386 and Z/A-916.7324. When I give a MB90 the motor moves 180, MB180 goes 360, MB360 goes 720, etc. It would seem that I need to divide the A value in half to get the correct moves. Do I also have to half the XYZ values also or do they stay the same? Thanks for your help.
    Norm
    Appling, GA
    Halve the UV for the A/B only. My guess is that you have a 3.6:1 motor in place of the factory standard 7.2:1 motor that came with PRT indexers. You UV will stay the same for all other axes.
    Going forward you might want to look for a higher reduction stepper since 3.6:1 is really too coarse for indexing in fine increments, especially if you are not running a 4G board with higher resolution.
    Dec 2005
    Lexington, TN
    Thank you Brady. Do I also half the current B value of 16.000 to 8.000? When I can get pulleys and belts, I will contact you for help computing the new values again. Many thanks again.
    Norm
    Yes - The lower number (16) is the number of steps to go 1 degree of movement. This is the value for a 7.2:1 motor. If you set it to 8, it will be correct.
    FYI - From the SB Command Ref PDF:
    Computing the Unit Value for an indexer would be done as follows, assuming you want to express the rotary
    motion in degrees. With an indexer having a 10:1 gearbox and with the alpha driver set at 500 steps/rev, we
    would have: (10 * 500) / 360 = 13.8889 [or, 13.8889 steps per degree].
    So...Let's proof it out:
    (3.6 * 800) / 360 = Rotary UV (8)
    Where 3.6 is your stepper gearbox ratio, 800 is the number of steps per revolution of the stepper (you have a 200 full steps per rev motor & you are 1/4 stepping with your 3G PRT box; so that is 200 X 4 = 800)
    You can use the same formula when you change the gear ratio on the headstock. Just plug in the numbers.
    Dec 2005
    Lexington, TN
    Brady,
    Thanks again for the information. I've ordered gearbelt pulleys and belt. Should get a 4:1 ratio with these. Will work on the math later......
    Norm
  1. Bit Chatter on xy moves only
    By barrowj in forum ShopBotter Message Board
    Last Post: 09-29-2014, 09:27 AM
  2. Moves too far
    By wayne_webb in forum ShopBotter Message Board
    Last Post: 08-24-2009, 12:20 PM
  3. +y moves half time, but -y moves normal
    By byoc in forum Archives2007
    Last Post: 06-14-2007, 04:17 PM
  4. Jittery during XYZ moves...
    By harryball in forum Archives2006
    Last Post: 11-04-2006, 01:43 AM
  5. StairStepped Z-moves
    By stickman in forum Archives2005
    Last Post: 09-20-2005, 04:46 PM
