I'm sure its not the first time it happened, but I sure am upset with myself right now. Looks like I accidentally save a cut file that was in metric when I actually wanted inches. Ran the file, and things didn't start off right. Stopped file. Wondered what was wrong and that's when I noticed the beginning of the cut file looked different to me. It had VD, and VA commands which normally aren't there. Went back to the programming computer and found out it was saved as a metric .sbp file. Went back to the CNC and looked up the VD, found it was in millimeters. Set it back to inches, but something is still wrong. When moving it seems like it wants to take off way to fast, and bad noises come from the motors, like slippage on gears. Possibly trying to move to fast for its ability? At least that's what I'm thinking. A unit value of some sort? Where does one go to find out what settings you should have?
What settings changed that I need to correct?
--Jim
