Results 1 to 10 of 12
Thread: Cutting Aluminum with 3d Software?
    Apr 2014
    New York
    Default Cutting Aluminum with 3d Software?
    Well I got my Shopbot desktop a couple weeks ago. It's all set up and I've made a few successful cuts into wax and modeling board. But I want to take things to the next step and start milling some aluminum.
    I've read through all the advice on milling aluminum (feeds, speeds, etc...) and I think I can handle that, but I'm having a little software issue. I want to do some 3d milling (all my files are .stl) but the 3d CAM software I've tried doesn't have any ramping options. I know most 2.5d programs that take .dxf and other drawing files support ramping. But my parts simply won't work as a drawing.
    So does anyone here do any 3d work in aluminum? What program do you use? (I've been using meshCAM). Any other possible fixes like using a drill mill, or just careful g-code editing?
    James, Maybe somebody else will chime in to tell me why you can't do it, but you should have gotten Partworks3D with your Desktop(Congratulations by the way). You can open your .stl in there and then depth of pass can be adjusted by your tool database bit selection parameters. Didn't see ramping anywhere in selections and not settable in VCP7.5. Don't trust me though---Wait for the big boys Thought this might help if you don't already have it.
    Attached Files Attached Files
    Apr 2014
    New York
    Yea I went through Partworks 3d a couple times, didn't see any ramping options. Not a fan of the program, I found MeshCAM easier to use than the seven step process. I guess it's just personal preference.
    Yeah, It's kind of clunky, but at least it's there and comes with all the machines which I appreciate. When it becomes too much of a pain we'll bite the bullet and go Aspire. Aspire Guys, I uninstalled Aspire demo---Can you ramp into 3D's?
    Apr 2014
    New York
    So I asked over on the MeshCAM forums how they use it for milling aluminum. They just plunge in with a center cutting end mill. So I'm going to give that a try, I'll just ease up on the plunge rate.
    Aug 2004
    Northern , new jersey
    Default Ramping
    I have not tried this but , if you make your tool path partworks 3D and then import it into Vcarve pro , there is a option for ramp in the tool path section .
    you could also read about ramping search " Brady Watson & ramping "on the Shopbot web site .
    this is within the Shopbot software type VR
    Mar 2009
    Pope Valley CA
    Hi Bob,
    You are showing the ramping options on a profile toolpath. It is not available for an imported Cut3D toolpath, nor from a rough or finish toolpath in Aspire.
    The ramping from Brady's blog post refers to the way the control software handles the way the machine deals with speed changes for things like corners - not ramping into the material for the cut.
    Ron Sloan
    Aug 2004
    Ron First let me say I have not used the Vectric software yet as I just got it with the desktop , Just pointing out that there was a option to import files from PW3D , and that there was a ramping option , as I said I did not try it . Sorry if that misled anybody
    As for Bradys blog , I know its the ramping for the machine software ,But If he is going to be doing 3D in aluminum , it might save a router bit or two , Its good reading
    He may have to up grade to a different software , Artcam Pro does ramp into 3D as pictured
    Mar 2009
    Pope Valley CA
    Hi Bob,
    I wasn't trying to adversarial about it - sorry if I came off that way.
    And you are absolutely correct about Brady's article - great read!
    Ron Sloan
    Apr 2014
    New York
    So I had a successful test tonight. I posted the same question over on the MeshCAM forums, was told a straight plunge with a center cutting endmill should be fine. Gave it a shot tonight and milled a little 0.5" x 0.5" pocket, about 0.04" deep. Zipped right through it. No walking on the plunge, no shaking, no chattering, no melting chips, just clean cutting.
    My settings:
    Endmill: 1/8", 2 flute, 45 degree helix, Center cutting, from Harvey Tool.
    RPM: 18,000
    IPM (X & Y): 54
    IPM (Z): 12
    G-Code: Created with MeshCAM
    A good start. I'll be doing some more testing on bigger cuts. If I get any interesting results I'll report back here. Thanks for the help so far.
  1. Cutting aluminum
    By Davo in forum ShopBotter Message Board
    Last Post: 07-09-2015, 10:35 AM
  2. Need help cutting Aluminum
    By sean_adams in forum Techniques for Cutting, Drilling, Machining
    Last Post: 07-06-2015, 11:37 AM
  3. aluminum cutting?
    By kclanton in forum ShopBotter Message Board
    Last Post: 01-11-2014, 12:35 PM
  4. Aluminum cutting?
    By pezsez in forum ShopBotter Message Board
    Last Post: 02-15-2009, 10:31 AM
  5. Cutting Aluminum
    By phardy79 in forum ShopBotter Message Board
    Last Post: 01-07-2009, 06:37 PM
