Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 51
Thread: Dimensional Accuracy
  1. #41
    When you tightened the set screws did you remove them first. On my pinions they have 2 one on top of the other. So if the bottom one is loose your pinion still may be loose.
  2. #42
    Sep 2008
    Quote Originally Posted by jamesmcbennett View Post
    Do you mean from SB3? Here is that http://imgur.com/a/GOraZ
    no thats the toolpath in vcp select vector right click node edit mode select vector again
    Vector Studio 22
  3. #43
    No James, click on selected vector in VCP, press N,take screenshot
    Dublin Ireland
    PROGRESS!
    I misunderstood what tighten pinions meant. This time I took the motors off and X1 and Y were both loose enough to fall off, the other two were fine. So did a quick cut at 9pm which I think turned out really well http://imgur.com/HMwTD2Q, but in residential neighbourhood, so will do a full test in the morning.
    Thanks to everyone for so much amazing support! Very appreciative!
  5. #45
    That is looking better.
  6. #46
    Sorry... likely I should have said “tighten the grub screws on the spur gears”
    But it looks like we’re getting there!
  7. #47
    Progress!
    Jan 2008
    When peoploe ask why I bought a ShopBot, this thread is exactly the answer! Nice job gang! Russ
    AKA: Da Train Guy
  9. #49
    James, Just in case you haven't watched it, TJ tapes all his classes. If you go down to machine maintenance, it might help. I usually try to attend them online because of the Q&A at the end of the class, but I think I skipped this one because it was on full size machines and we just have Desktops. I always learn stuff from TJ's classes. Sorry if you've already watched it.http://www.shopbottools.com/mSupport/tutorials.htm
    Dublin Ireland
    Reason I bought a ShopBot over anything else was also exclusively down to support and community, not just a machine. Thinking back to the last two months, not sure how I would have proceeded without it. Decision well made!
    I hadn't seen that Scott, thanks for link. (Still clearly a newbie!) and will learn something new this weekend!
    Have a great weekend everyone! Thanks for fixing my ShopBot
  1. dimensional sign help
    By BPACH in forum Sign Making
    Last Post: 12-31-2013, 04:06 PM
  2. Meaning of "Dimensional Sign"
    By carlosgmarroquin in forum Sign Making
    Last Post: 04-28-2009, 08:45 PM
  3. Dimensional sign.
    By toych in forum Folder 2009
    Last Post: 03-03-2009, 03:10 PM
  4. Dimensional Mahogany in Atlanta?
    By harryball in forum Product/Supplier List and Requests
    Last Post: 10-31-2008, 07:17 PM
  5. Dimensional SCustom Sign (PVC)
    By wingfield in forum Folder 2007
    Last Post: 07-27-2007, 10:03 AM
