Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Dimensional Accuracy
  1. #21
    May 2014
    Dublin Ireland
    After more tests, its seems that the cut is consistently out by 2.85mm on a range of cuts 18mm, 20mm, 22mm, 24mm, 26mm, 28mm, 30mm, 32mm, 34mm and 36mm.
    I have figured out that if I convert lines to either arcs or lines in rhino, then bring a DXF into VCarve that the kinks don't appear in the VCarve drawing but still appear in the CNC'd wood. Doesn't solve dimension problem, as this is a second problem, hope I don't confuse anyone.
  2. #22
    Feb 2004
    Sawdust and Noise, Brampton Ontario
    As the difference is consistent regardless of the size of the part the problem is not the Unit Values as these would give larger differences with larger moves.
    Your drawing shows that the part is being cut with a climb strategy. Any deflection using this strategy will result in oversize parts (undersized spaces) and the difference would be consistent regardless of the distance moved. If you changed to a conventional strategy you may find that the gaps become oversize (parts undersized) because of the same deflection. A strategy to produce the most accurately sized parts (if the problem is deflection) is to cut most of the way through the material (80 -90%) using a climb cut and then finish cutting in the conventional direction.
    As mentioned earlier an undersized bit would also cause an oversize part but changing cut direction will not have an effect.
  3. #23
    May 2014
    Dublin Ireland
    Climb Vs. Conventional
    http://imgur.com/atOvtUd
    Both are messed up, but differently.
    I need to get something built, so figuring out if it needs to be +3 or -3 in different places and is working. Not an ideal way to have to make something, but a temporary solution. Hope to get this fixed as soon as possible! Thanks for all the great support so far!
  4. #24
    May 2014
    Dublin Ireland
    http://imgur.com/ywjB0II
    This was intended to be 60mm long, but cut the hole 57mm (-3mm) and the leg 63mm (+3mm). So I remade a top that had the holes as 66mm and got holes as 63mm (-3mm) which fit the leg perfectly. So there is some game of three's going on.
    On the right side of both top and bottom joint, the corner has been snipped off the leg creating a slight gap. I don't think this has anything to do with hardware as the corner is snipped off every similar shape in the same position every time with the same dimension and angle of the kind of bevelled snip. The same is happening with the holes of the top. The top left corner of the bottom hole being snipped and if you rotate that hole 90 degrees anticlockwise to position of top hole, same corner snipped at same angle.
  5. #25
    Sep 2008
    what are you generating your toolpaths with? post the drawing
    Vector Studio 22
  6. #26
    Novato CA
    Quote Originally Posted by Simops View Post
    My bot is setup in imperial and I use imperial tools only.......I design many of my requirements in metric and occasionally in imperial and always use the inch PP......never a problem as SB3 does the conversion automatically and cuts are always spot on regardless whether imperial or metric.......great feature of SB3.
    Cheers
    Great to know thanks.
  7. #27
    May 2014
    Dublin Ireland
    I use Rhino5, then VCarvePro that came with my ShopBot, then SB3 to play file.
    Image attached that show various points of setting up VCarve. I export them to Shopbot file in MM.
    http://imgur.com/a/iiN2L
    Will try as suggested changing file to inches, SB3 to inches as bit is imperial 1/4 inch bit that came with the ShopBot.
  8. #28
    James, Newbie here, but wondering why you didn't "create fillets""dogbone" to .25" directly in VCarve? Both my Onsrud starter set .25's" are undersized. .246 and .247" respectively.
    May 2014
    Dublin Ireland
    Just taught myself a new trick, didn't know that feature was there......I'm very new.
  10. #30
    Did you measure your bits at the tip? Won't explain all your problems, but might help a little? Measure at least 5 times, Throw away high/lows and average middles(or keep going until you get 3 identical readings). Something is funky. Your pictures help a lot!
  1. dimensional sign help
    By BPACH in forum Sign Making
    Last Post: 12-31-2013, 04:06 PM
  2. Meaning of "Dimensional Sign"
    By carlosgmarroquin in forum Sign Making
    Last Post: 04-28-2009, 08:45 PM
  3. Dimensional sign.
    By toych in forum Folder 2009
    Last Post: 03-03-2009, 03:10 PM
  4. Dimensional Mahogany in Atlanta?
    By harryball in forum Product/Supplier List and Requests
    Last Post: 10-31-2008, 07:17 PM
  5. Dimensional SCustom Sign (PVC)
    By wingfield in forum Folder 2007
    Last Post: 07-27-2007, 10:03 AM
