When you tightened the set screws did you remove them first. On my pinions they have 2 one on top of the other. So if the bottom one is loose your pinion still may be loose.
No James, click on selected vector in VCP, press N,take screenshot
PROGRESS!
I misunderstood what tighten pinions meant. This time I took the motors off and X1 and Y were both loose enough to fall off, the other two were fine. So did a quick cut at 9pm which I think turned out really well http://imgur.com/HMwTD2Q, but in residential neighbourhood, so will do a full test in the morning.
Thanks to everyone for so much amazing support! Very appreciative!
That is looking better.
Sorry... likely I should have said “tighten the grub screws on the spur gears”
But it looks like we’re getting there!
Progress!
When peoploe ask why I bought a ShopBot, this thread is exactly the answer! Nice job gang! Russ
AKA: Da Train Guy
James, Just in case you haven't watched it, TJ tapes all his classes. If you go down to machine maintenance, it might help. I usually try to attend them online because of the Q&A at the end of the class, but I think I skipped this one because it was on full size machines and we just have Desktops. I always learn stuff from TJ's classes. Sorry if you've already watched it.http://www.shopbottools.com/mSupport/tutorials.htm
Reason I bought a ShopBot over anything else was also exclusively down to support and community, not just a machine. Thinking back to the last two months, not sure how I would have proceeded without it. Decision well made!
I hadn't seen that Scott, thanks for link. (Still clearly a newbie!) and will learn something new this weekend!
Have a great weekend everyone! Thanks for fixing my ShopBot
