Results 1 to 9 of 9
Thread: 3.8.10 - Keypad causing prox limit / z-play zeroing problems
    May 2014
    San Jose, CA
    Default 3.8.10 - Keypad causing prox limit / z-play zeroing problems
    Hi everyone. I spend sometime on a ShopBot that was upgraded to 3.8.10. Ever since, I've consistently run into a few problems, one of which I'll detail here. I'm hoping you all can help!
    When setting up a job, I do four things:
    • Zero x/y using prox switches
    • Use the keypad to jog the cutter to the origin of my board (take a picture of the x,y for when the system locks up :roll eyes
    • Zero the x/y
    • Zero the z using the contact plate
    After updating to 3.8.10, I very often find myself in a situation where XYzero.sbp or zzero.sbp lock up while trying to move the tool.
    Specifically:
    XYZero.sbp locks up on:
    line 98: If %(3) < &zup Then MZ, &zup
    zzero.sbp locks up on:
    line 64: if %(3) < &zup then MZ, &zup 'Make sure we're clear...
    Whenever it locks up, I have to kill all the shopbot processes and start over.
    I think it happens when I try to run a zeroing process (that requires tool movement) while the yellow Keypad is up. If I remember to close the keypad window before zeroing with prox switches or the plate, it doesn't seem to wedge up.
    Is this a known problem. Any thoughts on if a patch is available?
    Thanks!
    I would upgrade the control software to the latest and try
    Not sure Which Vectric you're running, but wouldn't hurt to upgrade all. Also like Jerry said upgrade to 3.8.14 from second link and update firmware. Hope it helps.
    http://http://www.talkshopbot.com/fo...ighlight=Patch
    http://shopbottools.com/mSupport/controlsoftware.htm
    Agreed, update to 3.8.14. 3.8.10 was one of the worst ones for issues of all kinds. After doing the update, reset to your default values.
    May 2014
    San Jose, CA
    Thanks everyone. I'll mention it to the owners!
    May 2014
    San Jose, CA
    Coming back to this. They upgraded their machine to 3.8.14 and it has many of the same problems, including a new one. Before when you moved back and forth too fast with the keypad, the system would just stop responding. The cutter would freeze in place. Now when you move back and forth too fast, the cutter will move uncontrollably in the last direction you sent until you kill the executable. I had to race to kill the app before finding out what it would do when it hit the end of the rails.
    That's not just the usual garbage software problem I've come to expect with these things. That's dangerous.
    Sep 2009
    Surrey, UK
    They have updated the firmware to go with the new versions they're installing haven't they?
    What version of SB3 were you running previously? Did the tool have these same problems? Why was the software upgraded? (Just for maintenance?)
    Many times the computer has a lot of background software running on it. Has the computer been gone through and ALL programs not required to run a robotic tool eliminated?
    You say "moving back and forth too fast"? Just curious which model Shopbot it is and what your move and jog speeds are set at.
  1. Router brushes causing problems?
    By matt_raymond60 in forum ShopBotter Message Board
    Last Post: 06-19-2012, 11:38 PM
  2. Zeroing (C3) prox problems
    By Richard Ford in forum ShopBotter Message Board
    Last Post: 07-03-2010, 10:07 PM
  3. Zeroing (C3) prox problems
    By Richard Ford in forum Troubleshooting
    Last Post: 07-03-2010, 09:41 AM
  4. PROX-LIMIT SWITCH HIT
    By radone in forum Archives2008
    Last Post: 11-10-2008, 04:12 PM
  5. Prox / limit switch problem
    By don in forum Archives2008
    Last Post: 10-11-2008, 09:49 PM
