Thread: Changing Spindle RPMs
    Jan 2014
    Spring Hill, KS
    Default Changing Spindle RPMs
    Good morning all,
    Just a quick question. While running a cut file, is there any way to change the spindle RPMs either during the cut without interrupting the process or is there a "command insert" that will change the spindle speed??
    I open the spindle speed control tool prior to cutting but once you start a cut file I am locked onto the "stop" button and can not move the mouse off of the stop button to open the spindle speed control. I know I can set the speeds per bit in the Vectric software PRIOR to making the cut file, and I know we can change the move and jog speeds by interupting the file and using the Insert Command Line function but is there a way to change spindle speeds without having to go all the way back to Vectric??
    Thanks in advance for sharing some of your extensive experience with a newbie!!
    Nicholas Traub
    Principal Graphic Designer
    Director of Traveling Exhibitions
    Traub Design Associates, Inc.
    _____________________________
    ShopBot PRS Standard 48x96
    2.2HP Spindle
    2 - 3.5HP Vacuum/Blowers
    1 - 6" Indexer
    1 - Digitizing Probe
    8 - Pneumatic alignment pistons
    1 - Pneumatic drill
    Grizzly 3HP 220v Cyclone Dust Collection
    Donek Drag Knife
    KentCNC Dust Boot
    Lenovo ThinkPad W510 running Windows 7
    Vectric VCarvePro
    Sketchup 2016
    Adobe Creative Suite
    Sep 2009
    Surrey, UK
    I change the speed directly on the VFD itself if I want to make an RPM change while a file is running.
    Never done but I would have thought you could change it on the spindle control window while the file is paused or insert a TR.
    A TR command can't be passed with a Pause/Insert. You can try it, but it won't do anything. There used to be a Shift +/- keystroke that would sort of work, but it was removed because it sort of didn't work.
    Depending on your VFD, you might be able to remove the control portion and extend it to the gantry with a longer Cat5 cable.
    "It’s easier to fool everyone than it is to convince them they've been fooled" - Mark Twain
  1. Desktop Spindle speed changing on it's own
    By Zamm in forum ShopBot Desktop
    Last Post: 04-09-2016, 11:59 AM
  2. Turning off spindle before changing bits?
    By mmak2916 in forum ShopBot Desktop
    Last Post: 02-15-2015, 03:34 PM
  3. changing spindle speed
    By gibl5s in forum ShopBotter Message Board
    Last Post: 11-01-2014, 01:01 PM
  4. changing spindle speed
    By frank134 in forum ShopBotter Message Board
    Last Post: 05-07-2011, 05:11 PM
  5. How to set up spindle control box to show rpms
    By matney_models in forum ShopBotter Message Board
    Last Post: 03-09-2010, 08:43 AM
