Results 1 to 10 of 16
Thread: Circular Mahogany Dining table
    Dec 2011
    Piedmont, SD
    Default Circular Mahogany Dining table
    While I realize the average consumer will scoff at anything veneered, you cannot produce an item like this any other way. Personally, I love the stuff, because of the outrageous beauty of the many exotics that are completely out of reach if it weren't for veneers. It's a privilege to be able to work with such a stunning cut of crotch mahogany, as opportunities don't come along every day.
    Picture #1 shows the Sketchup draft, which allowed me to "paint" a picture of the veneer on the model for ease of visualization for the customer. It was simply pulled from the vendor's online photo of what I picked from their inventory.
    Once received, it consumed a week to soften, dry and flatten the fragile, wavy pieces of veneer so I could begin working them without breaking - I needed to be as efficient as possible in all other stages...
    Naturally, I used the Shopbot to cut every curved piece of solid wood utilized in the construction of this table.(which was almost all of them). Even the triangle pattern for the veneers was generated on the bot.
    - If you've ever blocked the circumference of a circular table, you know fitting those blocks can be quite tedious and time consuming. Not so with the 'bot. Miters and curves were essentially perfect - only had to shave ~.030" off the ends when fitting the last two pieces. I left a "dog-ear" on the ends of each segment so I could clamp them end to end where they but- jointed along the perimeter, then pulled snug to table edge, trimming the ears off when complete.
    Finishing: Timber-mate mahogany wood filler was used to fill the very porous grain, followed by a boatload of sanding. Used Trans-tint brwn mahogany dye stain to balance solid blocking with the veneers, as the solids were a bit more pink than the veneer. Sealed with T77F63 Sherwin CAB acrylic, then water based "Crystal-lac" wood grain filler. 3 more coats of lacquer with power sanding between each to level finish/fillers and reduce build. (too much catalyzed finish will continue to cross link and crack to pieces over a number of years). After about a week of curing, wet sanded and rubbed out with Liberon "0000" steel wool and Guardsman furniture polish for a silky-smooth feel.
    Sep 2008
    very nice work...
    Vector Studio 22
    That's a beauty! Thanks for posting!
    Gorgeous work !
    Jeff,
    It takes more then just the ability to push a few buttons on the bot to create something like that, so i'd say that was about 90% talent.
    I don't think i could have done that so you should be very proud of your work and the way you fit all that together was perfect! Good job!
    Words of Wisdom:
    Jul 2009
    Harbour Grace Newfoundland
    Very nice its great to see
    Also most antiques have some form of veneer its not cheap .
    Lots of skill to pull that off
    Garland Tx
    Jeff…
    Does your bottom “Ring” have a brass overlay? Looks very nice!
    May 2011
    ny
    Great job very nice joinery, the finish is awesome.
    Delray Beach, FL
    Gorgeous piece of work. Coincidentally I did a circular crotch table with pull out leaves some years ago. The guy wanted a jupe table but didn't have the budget for that so we made it manual pullout on sliding dovetails instead of doing the geared mechanism. Did you work from raw veneer pieces or pre-laid sheets?
    I got my leaves from Herzog and if you haven't used them they are terrific, including having flitch photos and bundle quantity numbers on their website so you can pick exactly what you want.
    The whole process of selecting pieces like that, softening them, and then forming the parts is one of the things I love about furniture making. It feels like really making use of the whole ball of wax instead of the typical "decorator" design which is usually semi-mass produced **** out of some magazine.
    Jun 2013
    Pasadena, CA
    Stunning! I never worked with veneer and am wondering how you cut the triangular pieces that cleanly to snug up to each other without gaps or fuzz. I suppose that highly figured veneer sheet is quite brittle?
  1. Rustic hickory dining table and chairs
    By dlcw in forum Folder 2015
    Last Post: 08-24-2016, 10:08 AM
  2. Walnut dining table
    By jTr in forum Folder 2015
    Last Post: 11-04-2015, 08:52 AM
  3. Dining Table with Side Extensions
    Last Post: 07-21-2013, 05:02 PM
  4. Dining Table
    By Brian Harnett in forum Folder 2013
    Last Post: 01-27-2013, 10:14 PM
  5. Queen Anne Dining table leg
    By zeykr in forum ShopBotter Message Board
    Last Post: 08-29-2012, 10:06 AM
