Hi,
I am helping a friend set up a Shopbot PRT Standard router running Version 3.6.46 software.
This router does not have a tool changer but would like to make a macro to bring the router to a predetermined position at the front of the table to initiate manual tool changes
If I run X - Y Zero off the prox switches I can easily make a macro to accomplish this operation giving it a predetermined position (i.e. X 0, Y 36) within the macro. While this would work, it takes a lot of time to run macro.
He is also using a X - Y laser so that he can reset the X - Y Zero to any position on the table. When this is done I lose the original X - Y Zero setting.
Question: Is there a way via a macro to still bring the router to a predetermined position on the table for manual tool changes without running the X - Y Zero routine and then adding the necessary offset to bring the router to a predetermined tool change position? The goal would be to bring the router quickly to a predetermined tool change position no matter where the X - Y has been set on the table. Is this possible????
Any input, help would be appreciated.
John
