Thread: Z Axis Driver Problems | Gecko G202 Solution Needed
    May 2012
    Seymour, Wisconsin
    Default Z Axis Driver Problems | Gecko G202 Solution Needed
    Hello I just started looking for a G202 Driver.
    My Z stopped moving. Noticed the software was sending a command, the Z was moving on screen. Checked Z driver and light wasn't on. Switched Z and B Driver, Z worked perfect. B "Bad Driver". The led remained off on the Bad G202 Driver.
    Pictures:
    https://www.dropbox.com/sh/7dt9yw3xk...5jfmQjjVFWkcca
    Anyone have a Gecko G202? Suggestion?
    Should I change out the electrolytic capacitor or some other component? Has anyone had success servicing these units?
    Extreme delta t is a factor in this situation. I had cold (-20 F; 0 F) ambient operating temps this last season.
    Should I somehow use a G203 and build an digital invert circuit?
    Any help would be appreciated.
    Thanks!
    cnc solid | division of initial sound, llc
    18007764103
    cncsolid.com
    http://www.cncsolid.com
    initialsound.com
    http://www.initialsound.com
    I see you have an indexer why not use that one while your one the z is on is repaired
    , South Jordan Utah
    The G202 is still available from Geckodrive.com for $144 each plus shipping. Click on Products and then on Legacy Products.
  1. Shopbot PRS-S 4G Control box (V 4.17) w/ 4- G202 Gecko microstep drivers. Unused
    By mmitchellnh in forum For Sale/Wanted - ShopBot-related items only
    Last Post: 02-23-2017, 12:17 PM
  2. Elegant solution needed. Suggestions?
    By scottp55 in forum ShopBotter Message Board
    Last Post: 11-23-2014, 07:14 PM
  3. X axis gecko driver issue
    By maxmaxima91 in forum Troubleshooting
    Last Post: 07-10-2010, 10:09 AM
  4. Gecko G202 problem.
    By br928 in forum Archives2008
    Last Post: 11-02-2008, 01:48 PM
  5. Gecko G202 and G203v trivia
    By richards in forum Archives2007
    Last Post: 12-12-2007, 11:56 PM
