Results 1 to 10 of 11
Thread: Is the total depth of cut limited by flute length?
    Nov 2009
    Default Is the total depth of cut limited by flute length?
    I probably should know this by now and have searched the forum for an answer unsuccessfully, but does flute length limit how deep I can cut with a particular bit? For example, I am working on a project cutting 2' x 4' victorian corbels out of edge glued 1 3/4" Douglas fir. In order to keep the inside corners tight, I'd like to use a 1/4" diameter up spiral but am not finding any available that have a flute length 1 3/4" long. Is it possible to use a bit that has a 1" or 1 1/4" flute length to cut through the Fir?
    Jun 2007
    Hampton Roads, VA
    This is the actual cutting part of the tool. below the shank. C is flute length
    Nov 2009
    Hi Joe, I understand which part of the bit is the flute. My question is whether or not I can cut deeper (using multiple . 25 inch passes) to achieve a total depth that exceeds the bits flute length.
    Sep 2008
    yes you can as long as flute diameter is same as shank diameter...
    Vector Studio 22
    Oberg Brothers has what you want. They are Super Extra Long 1/4" - 2 Flute End Mill - 2" LOC - 4" OAL. Part Number: SL20014 - Call and order a few.
    Jun 2013
    Pasadena, CA
    Quote Originally Posted by ron_churches View Post
    .....whether or not I can cut deeper (using multiple . 25 inch passes) to achieve a total depth that exceeds the bits flute length.
    I think it is a yes and no answer. If you just cut vertical (e.g. boundary slot cutout) you can go moderately deeper than the flute unless the slot starts clogging. But obviously you can not cut horizontal or burn the wood with the rubbing shank.
    A longer bit like Brady suggests is the better choice. HTC also makes some long, extra long and extra extra long cutters for reasonable money (Made in US).
    Box Joint, Dovetail, Guilloche and MazeMaker Software Here
    Jun 2014
    Houghton Lake MI
    Ron I have some odd shaped box's I make and cut them out with the sb . The box is 2 1/2" tall and cut them out with a 3" up spiral bit with no problems ever. But I do use a blow gun once the cut reach's 50%
    WoodTech World, Vancouver Washington
    I agree with Gene. As long as the tool path is the same horizontally all the way down in the cut.
    May 2011
    ny
    Yes I do it all the time don't have an issue at all. As said shank diameter must be less than cutter diameter though thats obvious.
    Jun 2012
    Ohio
    Yes, I do it all the time, as well.
    I like a shorter CEL, unless the bits are tapered. Seems like they're quieter.
  1. Is it okay to cut deeper than the flute length of the bit?
    By hipstomp in forum Techniques for Cutting, Drilling, Machining
    Last Post: 02-04-2015, 01:41 AM
  2. Total Rookie w/ woodworking needs assist
    By JackM in forum ShopBot Desktop
    Last Post: 03-23-2013, 09:14 PM
  3. Total novices need help on tutorials please!
    By Bob Eustace in forum ShopBot Buddy
    Last Post: 09-19-2011, 08:10 PM
  4. What file keeps track of total run time on the shopbot computer?
    By knight_toolworks in forum Archives2008
    Last Post: 06-18-2008, 11:19 AM
  5. Limited DOS Memory
    By waynec in forum Archives thru2004
    Last Post: 10-07-2004, 12:29 AM
