Results 1 to 6 of 6
Thread: Warning light for when Sbot is running?
    Sep 2012
    Blaine Mn
    Default Warning light for when Sbot is running?
    One of my renters is a machinist with big CNCs and I notice that
    when his machines run there is a red strobe on top that flashes-
    seems like a good idea. I am kind of deaf-ish and getting kind of
    senile at times, and my machine is in a busy shop with people
    moving around and occasionally customer visiting the powder room
    which is very close to my bot. Has this been done? Seems like an
    obvious safety precaution? I have noticed that my non-contact
    voltage tester lights/flashes when placed close to the spindle, but
    I don't think the batteries would last long. Thanks Gene
    Mar 2009
    Parts and Templates, San Carlos CA
    I have an led light on my bot that activates when you push the spindle on button. you do have to have a power source for it. If I remember correctly I had to get a 24 v led. I don't have the issue of clients getting too close to it but its a great visual to make sure that you hit the spindle on button before the bit snaps.
    Not that that has ever happened to me in my shop, in the last week or so.
    David
    I have 2 rotating lights that are activated when the spindle starts it runs off one of the 12 volt plugs in the control box
    Sep 2009
    Surrey, UK
    The SB3 user guide actually mentions hooking up a warning light relay to switch 4. That switch is automatically activated when the tool is in motion.
    Jun 2012
    Philadelphia
    Adrian is right. you can piggyback right off of relay 4. you can also use any other open relay in your control box. Just be mindful of your voltages, for example my dust colector is set up to turn on/off automatically but because it runs off 110vac i needed a solid state relay. you can use SO x,1 to turn the relay on and SO x,0 to turn it off. X is the number of your relay. and if your really feelling spunky you can add those lines to the post processor!
    Sep 2012
    Blaine Mn
    Good info all. I guess I was more concerned about the spindle (which
    is a Chicom 2.2- so not run from the Sb software) but the cnc motion
    is also something to think about. The spindle is so quiet that I can't
    always hear it. I will be thinking this all thru. Thanks Gene
  1. Tool warning
    By capj209 in forum ShopBotter Message Board
    Last Post: 10-17-2015, 01:19 PM
  2. SBot acting weird
    By woodshopcnc in forum ShopBotter Message Board
    Last Post: 10-15-2013, 06:54 PM
  3. cnczone warning
    By ssflyer in forum ShopBotter Message Board
    Last Post: 12-12-2012, 02:53 PM
  4. Warning post
    By cnc_works in forum ShopBotter Message Board
    Last Post: 02-01-2011, 08:46 PM
  5. Screen Warning
    By GlenP in forum ShopBotter Message Board
    Last Post: 09-22-2010, 02:58 PM
