Has anyone else tried this? I keep getting an error, I tried to set up the configuration for shopbot, maybe I should try reading the owners manual
I replied to your email. I think the error is that your feedrate is set too high.
For some reason the email I sent you was blocked (message not allowed for policy reasons.)
Looks like 10 is the max on feedrate, when I set it to 10 it works,
Feed at 10 plung rate at 75. Is that inches a munit
Thanks for the help, I am a little new to all this , so for I only use aspire.
I look forward to making lots of dovetails
I've added the ability to specify feedrate in units/minute, and output the code in units/second.
This was the issue mentioned in the previous posts.
Gerry I just sent you a paypal...
Words of Wisdom:
I got some new bits to play with. I used a 3/16" upcut for the pins, and a 7/16 8° for the tails. Came out absolutely perfect.
Well, you have me convinced. I'll be sending some moola your way as soon as i get home from work.
I bought it but haven't had the time to even open it and go thru any info. So let me ask, has anybody made any dovetails with it yet? Any pictures you can post?
Scott? you seem to be the moist ambitious among most of us...have you? I don't recall Scott do you have a desktop? If so, does it have the ability to cut something over the edge? (like where you would have to mount a vertical vise)
Words of Wisdom:
