So, my Elmo Rietschle (approx 10 HP) regen blower is in transit.
I plan to get it plumbed up asap after it arrives. The electrician is coming to hook it up (as well as some other work) but I will be hooking the vacuum to the Buddy of course.
I am thinking the inlet will be about 2 1/2" based on other similar sized pumps. My plan is to break my 48" by 48" table into two 24" by 48" zones - using a 1.5" x 3" aluminum tube attached under the table and having a hole that will be centered in the middle of each zone (left and right of the powerstick).
If I have a 2 1/2" pipe coming off the pump, split into a Y with a valve on each branch going to the aluminum tube... would a 2" line be big enough to go to each zone of the table? The reason I ask is that 2" and under piping and valves are easy to get here, larger I will have to order in. Not an issue, but if 2" will do then I will try that first.
I can get spiral reinforces vacuum hose locally so that's no issue - since the Buddy obviously needs a flexible hook up.
If I have to go to a 2 1/2" valve - does it make any difference if you use the white PVC piping or the black ABS stuff? Both I'd have to order.
Andrew
