Results 1 to 10 of 13
Thread: Drilling path from Sketchup Vcarve 7.5 or Partworks
Hybrid View
    Feb 2014
    Riverside, CA
    Default Drilling path from Sketchup Vcarve 7.5 or Partworks
    Hello!
    We have been running our shopbot from sketchup files for student classes. This has been relatively smooth but one of the issues that we have come across is some difficulty in importing paths via the dxf 2d output. This works for large shapes once the vectors are joined, but poses a problem with holes designed for drilling paths.
    Partworks does not seem to recognize the 24 (or other # of segment) circles that we make for holes. This has led us to produce crosses where holes should be and then redraw the circles with partworks. This is possible for a couple of dozen holes, but unworkable for many more.
    Does anyone have a workaround for this? Anybody get partworks to recognize sketchup circles?
    Now we see that there is a new version of Vcarve (7.5) that is supposed to work more directly with sketchup? But the number does not match partworks that we have (which seems to be up to date). What is the corresponding partworks version that matches Vcarve Pro 7.5?
    Thanks for any help!
    If you're using a drilling toolpath, you could use squares as well. PW/VCP looks at the centers of them for the center point of drilling toolpaths.
    Feb 2013
    River Fall WI
    You can't drill square circles Scott, unless you call them "squrcles" then I still don't think shelf pins would fit in them.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    Dec 2008
    , Richmond Tx
    If you take an imported circle and highlight it, and then hit J on your keyboard it opens up the join box. click ok and it is now one circle.
    You would have to do it for each circle though.
    Why not just teach them to draw 2d in partworks? Then toolpath and go.
    A square is a work around, but it still may import sections instead of a closed vector??
    Kenneth
    Feb 2013
    River Fall WI
    Partsworks/Aspire have a long way to go when it is compared to stand along Cadd software. Do not get me wrong I like the software for something's but not being able to diemension from two points drives me nuts.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Sep 2008
    Kyle,
    You should add this to your already extensive "signature"...
    Vector Studio 22
    Feb 2014
    Riverside, CA
    Quote Originally Posted by ken_rychlik View Post
    Please forgive me for any formatting complications - I'm still new to this.
    Unfortunately I can't change the original designs from sketchup, that is from another part of the class and out of my hand. They work towards Maya and this is intro for all kinds of options that 3d modeling (2d actually in this case) can provide.
    Does anybody know about the new "interaction" that Vcarve 7.5 provides with sketchup?
    OUr Partworks does seem to be up to date, but I can't for the life of me figure out how it has better interaction with sketchup. But then this is the "shopbot" edition. I thought that Partworks=Vcarve, no?
    Peter
    PartsWorks is equal to VCP, but it's generally a bit behind when it comes to updates. Does PW have the check for updates in the help menu (I don't have PW to see)? After you have created a new file, you have to choose to import vectors from a file and that's where you can choose .skp files.
    Kyle, haven't you tried a hollow chisel mortiser bit on your bot yet? You don't know what your missing! There's an 'Add dimensions to the 2D drawing' tool in the Create Vectors tool group. ?
    Feb 2014
    Riverside, CA
    I'll give squares a try. We tried only higher number of segmented polygons and didn't think to try ones with fewer. But since partworks was unable to join those when selected to then be found by the vector selector, I'm not sure why it'll find the squares. We do need to have it find them based on size - there'll be hundreds as the assignments come in.
  1. sketchup vcarve pro
    By paul60 in forum ShopBotter Message Board
    Last Post: 03-12-2016, 05:57 AM
  2. Importing Sketchup cabinets to VCarve Pro
    By jTr in forum VCarvePro and PhotoVCarve
    Last Post: 10-08-2015, 11:49 AM
  3. Sketchup and Vcarve Pro or Aspire
    By sam_harbold in forum ShopBotter Message Board
    Last Post: 03-26-2014, 08:25 AM
  4. "Safe Z" on Drilling Tool Path
    By wegner81 in forum ShopBotter Message Board
    Last Post: 02-26-2009, 02:26 PM
  5. Can I import SketchUp into PartWorks 3D?
    By jporter in forum Archives2008
    Last Post: 07-30-2008, 04:43 PM
