Originally Posted by
jTr
I've found the under size issue to be true on any brand bit if measured with a caliper, regardless of physical limitations and variables discussed above.
To consider:
- Shank is very likely precise at .250 , being pulled from carbide tool stock
- in order to shape and sharpen, it is inevitable that you'll loose some material
= Average of .005 to .006 under size is to be expected, and quite amazing, really.
When is this a significant issue?
For me, it is dados. When using melamine, it can be dead on for a 3/4" material. As of late, my suppliers seem to run upwards of .015 over size. In generating computer shop drafts of cabinets and furniture, it is done with the assumption of exact material thickness, which is obviously never the case for the sheet goods.
How to cope?
Under-size dados with under size plywood = very acceptable results, and I've ceased burning energy worrying. I'm making cabinets, not engine parts. A fit with .015 wiggle room makes for smooth assembly, and no excessive gaps in critical locations upon completion.
Under-size dados with over size melamine = now I'm sweating. My current formula:
.005 under size bit makes a pocket that is .010 under size, since I'm loosing .005 on both sides of the cut.
.010 to .015 over size on melamine = .020 to .025 under sized dado for a proper fit.
As of late, my solution is to assign an offset of +.021 on the pocketing tool path for the dado layer in Part works/ V-carve Pro.
This typically results in a super-snug fit that is more urgently required with melamine.
Adjust according to results you are getting, and if frustrated, remember, this is far easier to remedy in the CNC world than dealing with dado blade shimming in a table saw!!!
This seems a good place to interject an oft - stated but important note: Be sure to use a down spiral for any pockets cut into sheet goods, especially melamine. Tool change to compression bits for profile cutting, and be certain your first pass plunges .030 to bury the up cut tip into the material, assuring the down cut flutes are hitting that delicate face.
Jeff
I have been making a lot of plywood puzzle parts as of late, with perpendicular joints using dog bones so everything merrys up flush. Well every time I cut the parts with the exact width of the material measured with digital calipers, they don't fit, too tight. I was freaking out, thinking the bot was losing accuracy or aspire was f'd somehow. so I kept doing this negative offset in the profile passes. trial and error and so frustrating. Now I totally realize its because of the bits being smaller than their actual labeling. DUH! of course they are. Now i'm going to go insane trying to figure out how to measure my ballnose bits.. eesh.
PRS Alpha 96" X 48" w/ 12" Z
6" Indexer
Aspire 8
