I am using Aspire to make my designs to run on my ShopBot Desktop but I can't find the post processor for the Desktop in their list. What post processor should I use.
Shopbot(arcs)(inch)(*sbp) should work
Vector Studio 22
David
I do not have Aspire , I have V Carve Pro , this may or may not be the same , Click on save tool path icon , in the next screen you should see the Shopbot post pross Hope this helps Bob
ArtCam Pro 9
VCarve Pro 8
Bob,
Can you tell me what post processor V Carve Pro says it is using? I have to choose from a long list in Aspire.
As Gene said Shopbot(arcs)(inch)(*sbp) same one for Aspire and V carve pro
David,
I am not using Aspire either, but from what I have read in the past, I believe that Aspire, V Carve Pro, and Partworks use the same post processors. Its possible that they all did not load when you installed the software. I am attaching a zip file of all of the post processors I have for Partworks. Find where your post processors are for Aspire are located on your (C) drive; open up the zip file and drop these in there. (That file is probably located here or close to it: (C/Program Files/ShopBot/Aspire/PostP). Close Aspire and re-open it. Keep a copy of the PostP that Im sending incase you need them in the future. Use the PostP that Gene sugested. Hope this helps you out.
Sincerely,
Ben Nellenback
www.stairsmiths.com
"Bodily decay is gloomy in prospect, but of all human contemplations the most abhorrent is body without mind."
Thomas Jefferson
My bad David, When I wrote my previous post, I didnt realize you had a list of PostP's. I missed that post.
Sincerely,
Ben Nellenback
www.stairsmiths.com
Thomas Jefferson
Thanks anyway Ben. I do have a list. I got it figured out.
