Results 1 to 10 of 13
Thread: I think I ruined my Maple Countertop :(
    Jul 2011
    Atlanta, GA
    Default I think I ruined my Maple Countertop :(
    So I finally started to apply a finish to my hard maple counter for my kitchen island. I applied Waterlox to the bottom side first to "test" it out and I don't really like it because it has too much of an amber color, and I would like something more clear for the top side. But then I noticed that the waterlox had bled thru to the endgrain on the edges So I guess I'm screwed at this point or is there somthing I can do to get rid of the dark spots where it bled thru?
    Paul, Not sure about Waterlox, but if it happened to me with Tung/Linseed/or Watco I would saturate multiple times with a solvent as soon as possible and then wick it out as much as possible with clean rags or paper towels and flood again and again to thin it down. Angle the piece so none gets on top--It won't totally eliminate it but will help and what it doesn't get will blend in a little.
    Most finishes darken end grain a bit anyway, so maybe your choice of final finish depending on how it drys can blend it even more. For the above finishes I'd probably use a fast drying solvent like Naptha or citrus solvent, but look at Waterlox can to find out what they use as solvent. The quicker the better.
    Hope it helps or others have better suggestions.
    Scott Plaisted
    2013 Desktop/spindle/VCP 9
    Delray Beach, FL
    Waterlox Tung Oil?
    You should be able to leach it out with Acetone.
    May 2012
    Sun City West AZ
    yep, I would try acetone. lots of air, windows open , mask on.
    Jul 2011
    Atlanta, GA
    It's the Waterlox Original Tung Oil and unfortunately the acetone didn't remove it. So it looks like I'll be stuck with using Waterlox on the top side and hopefully the spots that leeched thru won't be that noticeable. My main complaint with the waterlox was that it had an amber tint. Do you think if I add some blue transtint dye that it will help neutralize the amber tint?
    Garland Tx
    “blue transtint dye”
    Like the “Bluing” elderly ladies used to treat their yellowing hair… Try it on a scrap. I’d like to know how it turns out!
    Delray Beach, FL
    Paul:
    I've removed mutiple layers of old dried in the sun teak oil and dirt from teak with a thick slurry using Tide and TSP as the base, adding a bit of clorox, and a scrub brush. You might try that. Basically you need to soften up the oil on the surface and then clean, bleach it.
    You also might try wood bleach (Oxalic acid) available at Rockler I would imagine.
    If you try Oxalic, make sure you either neutralize(they sell bleach neutralizer) afterwards or flush with plenty of water to dilute, as with maple(and other woods that aren't oily also I imagine-ask how I know) if left in the wood, it can punk it pretty bad.
    Dave, been a while since I mixed up a bunch of crystals to attack grey and/or gummed up teak with a bristle brush---You actually sound like you know boats!
    Scott Plaisted
    Jul 2011
    Atlanta, GA
    Quote Originally Posted by steve_g View Post
    Yep, that blue. I know that when using paint, if you choose two colors that are opposite of each other on the color wheel, then they will neutralize each other. So I was hoping I could neutralize the amber tint by adding some blue. If this doesn't work, then I'll try the Tide & TSP cleaner. Thanks for all the help
    Delray Beach, FL
    Paid for my daily rice bowl building/re-modeling/repairing them for 30 years. All shapes/all sizes!
  1. Help! I just ruined a desk for the 2nd time
    By pkirby in forum ShopBotter Message Board
    Last Post: 02-11-2014, 08:55 PM
  2. Speed/Feed suggestions for Corian countertop
    By larrymci in forum Techniques for Cutting, Drilling, Machining
    Last Post: 04-07-2010, 07:23 AM
  3. holding 3X3 maple
    By toddmaci in forum ShopBotter Message Board
    Last Post: 03-26-2010, 01:45 AM
  4. Shopbot for solid surface countertop applications
    By dlinder33 in forum Archives2006
    Last Post: 05-23-2006, 04:16 PM
  5. Replies: 1
    Last Post: 05-17-2006, 06:00 AM
