Dick:
See my suggestions below. Please check out what I said before getting into anymore software modifications.
After that if you still have no joy: Since you "reloaded" SB3, did you reload the same version you had been using or load a newer version?
If you loaded a newer version (a common suggestion by SB: "You should load our newest control software"), are you sure that you got the firmware updated properly? Frankly, the firmware update system is a little weird and it is easy to think that it was done correctly when in fact it wasn't.
Reloading in and of itself has caused some folks issues as some files apparently don't always overwrite smoothly or "residue" from older registry files causes problems and it takes an in depth wipe (more than just the usual "delete program" from the control panel software manager) to get it to run correctly again.
Some versions have had z-zeroing issues with some computers. One user will have no issues at all and another just can't get it to run right. These issues are in various versions of 3.8xx. Supposedly the latest version have fixed this but I'm still somewhat skeptical.
This really isn't the place to get into the discussion of trying to make the control software run on virtually any computer regardless of op system or version rather than SB just offering an operating computer that works, period, but it is a long standing debate that is regularly discussed elsewhere on the forum.
Dick: Dump the latest software. Re-load your favorite no problem older version. If you don't still have it let me know. I've got a bunch of them stashed.
Start at the beginning-check all the connections. Your problem was not software, it was hardware.
