Results 1 to 9 of 9
Thread: cutting a wave shape in the z axis along x axis?
    Jun 2008
    PS Joinery uk Ltd, middlesbrough cleveland
    Default cutting a wave shape in the z axis along x axis?
    HI Guys and Gals
    I would like to know if this is possible please.
    I would like to cut along a straight line in the x axis with the z axis following a wave shape in the z axis. I've done something similar in partworks 3d, but this takes around a thousand years. Can i get my shop bot to run along the x axis following a wave shape without making a 3d file?
    I am using partworks and i know that it is possible to ramp in and out of lines but i would like a continuous line. Any help greatly appreciated.
    would also like to upload a picture of what i mean but it's asking for a URL?
    Sid
    Habitat For Bats, Jackson GA
    You could create the wave you want on the Y axis, output the file then manually edit the .sbp files changing the y moves to z moves.
    /RB
    Sep 2009
    Surrey, UK
    You could do it with a fluting toolpath in the later versions of VCarve/Partworks and I seem to remember a ShopBot labs program that would swap X/Y/Z values as suggested above.
    May 2014
    Tucson, AZ
    Try http://paulrowntree.weebly.com . The standing wave is a gadget that makes wave shapes. It's pretty cool!
    Jim
    96 x 60 PRSalpha, 5HP Colombo spindle, Custom indexer, Custom vacuum table, Custom Fire Extinguishing System
    Jul 2013
    Dothan AL
    Exclamation
    There is a gadget for VCP that should do what you want if I understand what you want.
    Called "Flute Plus"
    Do a search over at the vetric forum and you will find a link.
    Jun 2011
    Melbourne, Australia
    This could solve your problem Sid.
    http://youtu.be/Gy8CJjpwZdI
    2.2 HSD Spindle
    Aspire 9.5
    6" ShopBot Indexer
    Oct 2000
    Willis Wharf, VA
    Hey Sid...there's a utility included in the ShopBot install that may do what you want. It's called the "Flipper" and is installed by default in the "C:\Program Files (x86)\ShopBot\Virtual Tools\Extruder" folder. It takes a profile drawn flat in VCarve or Partworks and basically flips it on edge, so that X or Y axis moves become Z-axis moves.
    If you want to do a surface with waves instead of just a single pass, the "Extruder" might do what you want. It's available in the Tools menu in the ShopBot software.
    Bill
    Also depending on the shape you need, a lot can be done with just the standard fluting toolpath. All this junk is done with a .5" Ballnose.
    Next to the smiley face on top row is the paperclip with an arrow, then browse for your pic after making sure it's say a .jpg of 900X600.
    Jun 2008
    Hello everybody,
    Thanks for your input, gadgets seemed like something quite interesting but this meant i had to upgrade to latest version of v carve pro ( thanks to Diane at Shopbot - new version installed).
    I will try all the methods and see what one works best.
    Thanks again
  1. Z axis keeps cutting deep
    By Davo in forum ShopBotter Message Board
    Last Post: 03-01-2015, 01:15 PM
  2. Z Axis Dust Control, while cutting HDU?
    By mjindustry in forum ShopBotter Message Board
    Last Post: 06-15-2010, 10:56 PM
  3. Z axis cutting depth errors
    By huntfairchase in forum Troubleshooting
    Last Post: 02-01-2010, 02:25 AM
  4. Z axis cutting to deep
    By hrdwrkr in forum Troubleshooting
    Last Post: 07-20-2009, 11:50 AM
  5. Cutting an arc in Z axis - I think
    By gary_k in forum Archive2008
    Last Post: 07-11-2008, 04:00 PM
