Originally Posted by
bradywatson
David,
If you raise up the entire gantry under the end plates 3", it'll be *perfect* with the factory Z. It doesn't cost much to raise it up using AL extrusion and splice plates from 8020.net - There is nothing you can do to the factory configuration to get more Z travel without adding something to lift up the gantry or drilling holes to lower the entire table down. Having done each at customers' requests - it is far easier to raise up the gantry. I'll spare you the details unless you are interested. It's way easier than you may be imagining & if you don't like it, stock config is just a few bolts away. If you're crafty, I've given you all the info you need...
Brady there is a 80-20 dealer in Sydney here but I spoke to him some time ago and he could not match up the extrusion exactly so I shied away from further enquiries......now this thread has reminded me about this again......maybe it's because he only had metric......I gather it's imperial of course! Do you have a 80-20 part number for the extrusion.....might have to look at whether it's viable to import an imperial part?
Cheers
