Results 11 to 20 of 28
Thread: Tried roundover cutter
  1. #11
    Jul 2013
    Dothan AL
    As much as I've explored, there is still a lot out there that I have not seen. thanx for the leads.
  2. #12
    These have a lot more uses than just rounding over the outside edge of a profile cut and you can work with any thickness of material unlike plunge cutting roundovers which aren't as versatile.
    Not very impressed with Rockler bits as a whole compared to other bits recommended here for CNC work, although I do use their keyhole occasionally.
    Scott P.
    2013 Desktop/spindle/VCP 10
    Nov 2008
    Keep in mind if you want the good roundover then your depth of cut= radius of roundover..
    and i used the roundover for plunge machning 2mm doc/pass..
    I left woodwork due to office work.
  4. #14
    Nov 2008
    if i was you i would purchase 5pcs/70dollar with free shipping..
    http://www.aliexpress.com/item/NEW-5...770983626.html
  5. #15
    Nov 2008
    In my country i am getting 1USdollar / piece
  6. #16
    Feb 2010
    SOUTH CENTRAL COLORADO
    Recent experience. The last 2 or 3 plaques I used a brand new Magnate round over. My rpm is 10k, my feed is 3.3 inch per second, my plunge 1 inch per second, my direction is climb and .08 pass depth and i add ramps. I get a smooth cut going with the grain but against the grain i get a real rough chip out effect. With my profile cut out i use a quarter inch end mill and every thing works fine. Any ideas.
  7. #17
    Rick, Is that the 1/2"Radius plunge roundover you linked above?
    I only use Pointed Roundovers, but speed seems low,and feed a little high for Walnut.
    Have you tried editing the passes so the last 2-3 passes are very light(.02-.03") and a final pass at .01"?
    I usually get a slight rough spot, but it's at 45 degrees to the grain, and it moves 90 degrees depending on climb or conventional, but similar in slight roughness.
    Just a thought, but mine need just a touch of 320 and 600G to look like this(only pic I could find, but walnut keyfob batches cut the same with a Whiteside .25"R)
    Totally different bit though.
    Did it just start happening?
    Scott P.
    Feb 2010
    i will try making that adjustment and see what happens.
  9. #19
    OH, Were you spiral ramping?
    It's the only way I do my cutouts.
    Almost exclusively a conventional cut here.
    Hope it works with that cutter!
    Scott P.
    Feb 2010
    I cut some poplar today, slowed down the speed rate a tad and turned the rpm up one notch. Smooth as a baby's butt, but we will see what it does on black walnut next time
  1. Point roundover bit
    By Kyle Stapleton in forum ShopBotter Message Board
    Last Post: 11-08-2016, 10:07 PM
  2. Roundover Profile
    By jimmya in forum ShopBotter Message Board
    Last Post: 08-29-2012, 07:20 PM
  3. Fun with Roundover bits
    By rcnewcomb in forum Indexer
    Last Post: 10-30-2009, 02:36 PM
  4. Roundover is it practial?
    By knight_toolworks in forum Archives2008
    Last Post: 12-10-2008, 08:10 AM
  5. 1" Roundover Bit
    By erik_f in forum Archives2004
    Last Post: 05-10-2004, 07:37 AM
