Steve, Glad to see you're getting comfortable enough to play with it and I agree with G. that I only look at chipload calculator as a suggestion for totally different bits than I've never used before.
I only changed to a climb cut yesterday when I notice my wasteside cut was cleaner than the workpiece side. About 90% of my cuts with Downs is conventional. Also noticed my house carpenters writing on that scrap which places it at about "96. Thing I'd try next is can you get back up to 1/2 diameter or greater pass depth. No idea why my setting was at .09" except I was cutting quilted last week and maybe hit apply, but my CenturionFEMLH is at same pass depth but 1.1,.5,10K which is Teak/Jatoba speed.
Thing is , whatever works--Works. Keep an eye on your chips and feel the bit after a short time(should always be able to keep your finger on it) for temp. Listen like you did and the bit will usually tell you, a hand on the machine will tell you about small vibrations that can affect cut. Also found that some move speeds are smoother than others even under No load, set your radio buttons for a couple long X,Y moves and run through the move speeds and find the smoothest and roughest setting and write them down and try to use the smooth ones(hand on machine frame for vibration/resonance).
GOT to try Bradys settings now
Nothing is written in stone, and it can change from board to board, be glad you have a spindle and can reach around and tweak it.
My Downs are the only bits I ever have to use ear protection on
