Here are some examples of dedicated fixture hold down with ZBC CR 06 LF 24 .
Here is an example of on board gasket CR 06 25
Here is All Star Adhesive Products 2 zone demo grid table with a 1/4 HP rotary vane Gast PSI pump.
Thanks for pics George, In the first 4 pics using the cover gasket what was the spoilboard material?
Also for that button hold down sketch you made me, were you recommending pulling through MDF after skimming both sides and sealing edges and then covering the entire surface with your cover gasket?
Thanks again to you and John.
We used MDF but I would not recommend it to inconsistent. I would use a solid piece of hdpe or something along those lines. if you get me the size of the button, roughly the size of the material you are cutting the buttons out of, and the bit that you are using to cut the buttons out with. I will get you on the right track for a fixture set up
Thanks George, Will do after I get several things straightened away for winter.
