Results 11 to 20 of 23
Thread: Vacuum Fixtures
  1. #11
    Garland Tx
    http://www.talkshopbot.com/forum/sho...highlight=gast
    The Gast pumps have been well spoken of in the past
    sg
  2. #12
    Aug 2004
    Northern , new jersey
    Default vac pump
    What you do not want is a vac pump for service air cond . as they are rotary vane type with a oil res. ,, One like joewoodworker.com is a dry diaphragm type and cycles on and off as needed
    ArtCam Pro 9
    VCarve Pro 8
  3. #13
    May 2014
    Detroit MI
    Gast oil less rotary vane and Thomas diaphragm pumps are the most common. Most of the cheap pumps on Amazon are the oil spewing variety.
  4. #14
    Jun 2013
    Pasadena, CA
    Get one of the oil-less GAST or Thomson pumps that are being sold refurbished on e-bay for $150 or so (Google). They usually come with starter capacitor and power cable (check). No oil and they can run for days continuously. I guess they are more industrial than a Chinese consumer device.
    HDPE is fabulous for pods but since I have unintentionally destroyed a few I just use 3/4" Baltic or even solid wood. The porosity is insignificant compared to other leakages (work piece, seals etc.). Another advantage is better friction on the table. The HDPE pods tend to slide around on my aluminum table when not bolted down well. I use 3/8" foam o-ring cord from McMaster. The o-ring channel is undercut with a ball end bit so that the o-ring is captive and can not jump out.
    I use a standard size pod (5x5" or 5x9") for surface cuts that don't go through and where the material is rigid. For through-cuts and flexible material I make disposable "spoil adapters" that sit on top of the pod with a few through holes and adhesive 3/16" flat gasketing tape around the known un-cut areas. To avoid flexible material to be sucked/bowed in between the gaskets, I may create a gasket grid pattern that supports the entire surface evenly. I heard Allstar is good quality gasket but have not tried it yet. I usually take the rubber foam weather strip (Frost King R338H) from the hardware store that compresses under vacuum to less than 20/1000" but will recover. When replacement is needed it scrapes off with a chisel easily
  5. #15
    Sep 2012
    Blaine Mn
    The ones on ebay seem to be 1/3 HP- how much of a vac fixture
    will that support? Thinking 18x36" approx. Thanks Gene
  6. #16
    May 2014
    Detroit MI
    Depends on how much leakage you have, and/or how porous the material you're holding. My 1/4HP Gast is rated at 3CFM.
  7. #17
    Jun 2013
    Pasadena, CA
    Quote Originally Posted by GeneMpls View Post
    I have one that is 3/4 hp and it can do four 5x5 pods holding solid wood or plywood.
    For 18x36 you will need more volume. For such a large surface you may be better off with a Fein or Lighthouse.
  8. #18
    Jan 2011
    gleason, wi 54435
    Yes gasketing should pull down to 0. Makes your Z much more predictable. I use 3/8 O.D. surgeons tubing (like you used to make sling shots out of). I have even used the round weather seal material from Home Depot in a pinch. Allstar gasketing sells excellent vacuum stuff although a little pricey it works great (try their cover gasket for dedicated fixturing with a central vac motor). Brady Watson and some others did extensive research and writing about vacuum on this forum if you can search the archives. Bob
  9. #19
    Nov 2013
    RI
    Default All Star Gasketing
    We are working on making up half rolls for the folks that are not in the high production end of the cnc world. Hope fully that will make the cost more affordable to the guys with the smaller machines.
  10. #20
    Cleveland TN
    Bob, is that the same as Latex Surgical tubing, Amazon sells 50' of 1/4"id - 3/8"od for $28 Prime
    2005 PRT Alpha 48x96
    2013 Colombo 3hp spindle
    Indexer (converted lathe)
    Aspire 9.0
  1. Hold down fixtures (material to use)
    By BPM in forum ShopBotter Message Board
    Last Post: 11-26-2014, 07:01 PM
  2. Dedacated Fixtures/ Vacuum hold down
    By gbradley in forum Techniques for Cutting, Drilling, Machining
    Last Post: 11-03-2014, 06:50 PM
  3. Software for Fixtures used In-line with SolidWord/Autocam
    By BrandanS in forum ShopBotter Message Board
    Last Post: 03-31-2014, 02:43 PM
  4. A couple of table fixtures
    By mzettl in forum Archives2008
    Last Post: 06-29-2008, 05:21 PM
  5. Bt32/48 vacuum fixtures
    By dana_swift in forum Archives2008
    Last Post: 04-07-2008, 08:14 PM
