Results 1 to 10 of 10
Thread: Changing Feed Speeds while cutting
    Mar 2008
    The Adventurer's Outlet, Bolton MA
    Default Changing Feed Speeds while cutting
    Hi Everyone
    Does anyone know if there is a way you can change the feed speed of a cutter while the part is running? A dynamic speed control if you will.
    Ben
    Jun 2007
    Hampton Roads, VA
    Shift + > or Shift + < to lower.
    Happy Veterans Day.
    Dec 2011
    Piedmont, SD
    Ben,
    SHIFT < or > to decrease/increase feed speeds using your keyboard. Increments in .10 steps either direction. Response is delayed if you do so while cornering, smoother if done while following a straight vector.
    Also, expect to notice a little rougher cornering after increasing speed. Altering MS on the fly seems to disrupt the algorithm that ramps / smooths speeds when cornering. Once you're comfortable with proper rate, you'll want to set this in the part file for optimal performance.
    In short: only use this occasionally as an aid to ascertaining optimal feed speeds.
    jeff
    To maintain proper ramping, use spacebar/insert/MS/change the values/enter/resume.
    I will use the shift plus <> to change then when I get to the speed that sounds right I hit the space bar and then resume to get the ramp set.
    I've gotten into the habit of never changing my linear speed more than .4IPS before I go back to the original file and changing it! Much better results on small VCarves(Ala Brady).
    It really affects cut quality on VCarving(especially corners and reverse directions).
    Jerry, does Pause/Resume affect Ramp Settings?
    Apr 2011
    near Atlanta, Georgia
    Newbie here but when changing speeds dynamically, how does one know what the updated speed is or did I just not see it on the screen when I did it?
    Watch the move/cut speed value in the console as you do it.
    Mar 2009
    n/a, Vancouver BC
    Does anybody know if the ramping speed issue with bumping feed up or down while running a part file has been resolved? I am on version 3.6.44
    thanks, Jon
    No it hasn't. Just stop the tool via S key or spacebar, I then MS and enter new speed. It will then recalculate with proper ramping.
  1. Feed and Speeds
    By maginter in forum Archives2008
    Last Post: 06-23-2008, 01:13 PM
  2. Feed speeds and getting them to the bot
    By mountie1808 in forum Archives2007
    Last Post: 06-22-2007, 07:16 AM
  3. Changing feed rate on the fly
    By jdelbeke in forum Archives2006
    Last Post: 02-09-2006, 05:50 PM
  4. Feed and speeds
    By jthelen in forum Archives2004
    Last Post: 12-10-2004, 05:00 PM
  5. Changing feed rate while running program
    By chandler@n-link.com in forum Archives thru 2002
    Last Post: 07-05-2001, 10:52 PM
