Does anyone have a method for making a beach ball type sphere? I have found some templates online but want to actually know the math or method.
David
David
What size? Just a sphere or with some pattern? With or without rotary axis?
I need the unwrapped sphere. As if you were making a beach ball with 6 panels. The actual piece is to be 6 feet in diameter
Ah...sorry if I just don't get what you want to do but each of these panels would still be 3-dimensional. While you can unwrap a cylinder or a cone on a flat surface you can not unwrap a sphere or ellipsoid. The best you could do is segment the surface into a faceted polyhedron. I have been working a bit on such tools lately but I don't know if that is what you need.
As in many things, you have to know what to search on in order to find the answer. I was looking for a GORE CURVE, most commonly found on pages about globes or parachutes. The method I ended up using (and using Aspire) is to draw a rectangle, width is the circumference of the sphere, the height is one half the circumference. Draw a line as an equator across the length of the rectangle. Divide it into as many sections as you want, the more sections, the more it will resemble a sphere when put together. I used the copy object along vectors tool to space 7 circles along the line for six spaces. Divide the space in half top to bottom. Use the three point curve tool to draw from the midpoint of the section top to the edge of the rectangle. Mirror across while making copies and you should end up with 6 pointed footballs. here is the site that explained it the best http://octopus.gma.org/surfing/imaging/globe.html
That would work if you use thin flexible plywood or other sheet that can be bent. Is that the plan?
Not my plan, but it's the clients plan. If I'm feeling nice I may offer to drill holes so they can sew up the ply. They are going to use bending poplar.
The problem with bending (or any) ply is it only bends in one direction. Designs of curved panels to be built from plywood need to take that into account. In boat building hull designs made for plywood take this into account and are called "developable". When the pieces are bent in the polar direction they won't bend equatorially. They can have a go at it but if I were you I would take responsibility for cutting parts only with no guarantee of success in construction. The edges of the ply where the sections come together also will vary from 90 degrees as they go from the equator to the poles. That's why they use steamed wood for barrel making. They have to deform the staves to get the curve.
Hi David
"but want to actually know the math or method. "
I have a sheet metal background and have used several methods to develop a Sphere pattern. his is one.
Looks like i need help posting this.
not sure why the math page is not posting,
