Results 1 to 10 of 12
Thread: cutting bamboo ply
    Sep 2011
    New Hampshire
    Default cutting bamboo ply
    Has anyone cut cabinet door and drawers out of 3/4" bamboo sheets. I would like to use an 1/8" cutter to minimize the kerf between parts. My default is a 3/8" compression but I was wondering if a smaller diameter bit will work if I take slow shallow cuts.
    Todd
    Theoretically yes but be prepared to break some bits! That's a long cel for a bit that small in material that hard. Best done on a table saw. Bamboo has such a straight grain you may not hardly notice the difference between an 1/8" bit and say a 1/4".
    Sep 2011
    New Hampshire
    thanks dave
    I think what I will do is tell ecabs all the cabs are the standard drawer on door bases and then cut the bottom door into drawer faces when needed. I was trying to avoid manual labor but sometimes it seems the better way to go.
    May 2005
    Londonderry New Hampshire
    Default Bamboo
    3/8 would be better but expect it to be noisy....wicked hard stuff to mill
    Dick
    Aspire 10.5
    Jun 2013
    Pasadena, CA
    I made my bathroom cabinets from bamboo (see old thread here) and cut pretty much everything with 1/8" bits (2-flute fishtail upcut). Maybe not the fastest method but I usually do 2 ips, 13krpm and 1/8 to 1/10" deep for such bamboo plywood. No problem and very clean cut.
    Todd, Agree with G. on Fishtails--May not be fast enough for you though. Super clean sidewalls and virtually no splintering at all--Just did 20yr old Indian Rosewood 2 days ago.
    Makes sense as they're made for things like frets and other Luthier work and their material is sometimes old/dry/ but always expensive. Made to leave a pocket bottom suitable for gluing though. Tips are aggressive and good drilling holes using Inside/Profile/Spiral Ramped cuts also.
    Good luck.
    Sep 2011
    New Hampshire
    Thank you for all your inputs. I think the slow cutting of the 1/8" cutter is worth the trade off for speed from the 3/8" compression I am accustom to. What is a fish tail cutter and where should I purchase one.
    Todd
    Hi Todd, PreciseBits is where I got my .117"2Flute-Think minimum order was 8 of them.
    Just bought some bits from Drillman1 on E-bay but haven't tried his fishtails. Like everything else bought from him which is why I ordered $140 of various 1/8'ths to split between the 2 shops
    http://www.precisebits.com/gateways/EndMillsHome.htm
    Sep 2011
    New Hampshire
    Thank you scott. I went to the link and did not find one with a cutting length of 3/4".
    Jun 2013
    Pasadena, CA
    I am not sure if PreciseBits has one with long enough straight section to cut through 3/4" sheet. At least the one I got is too short with a 1/4" shank.
    I do use the Drillman1 1/8" bits which are 2" long and leave more in the collet for 3/4" deep cut than the usual 1.5" long bits of that shank diameter. The flute length is 0.625 but that is O.K. because you do not go 3/4" deep in one step.
    I rarely wear them out. Usually I run them for a long time and at some point break them by mistake but at $5 each no big problem.
  1. Bamboo Plywood
    By Justin G in forum Product/Supplier List and Requests
    Last Post: 01-20-2016, 06:14 PM
  2. cutting bamboo
    By twelchPTM in forum Techniques for Cutting, Drilling, Machining
    Last Post: 06-13-2015, 12:24 AM
  3. Custom Bamboo Cutting Board
    By wberminio in forum Folder 2010
    Last Post: 03-12-2010, 02:03 PM
  4. BAMBOO
    By coach in forum Techniques for Cutting, Drilling, Machining
    Last Post: 04-08-2009, 07:47 AM
  5. Cutting bamboo plywood is great But watch out
    By knight_toolworks in forum Archives2007
    Last Post: 06-19-2007, 11:52 PM
