Well we are at our first one
Kyle Stapleton
Desktop w/spindle
Potter Pen
Aspire 8.5, Creo 3.0
Good Luck Kyle!
Is enclosure 3 sides and just slid on?
Did she travel easy enough on cart?
Cart work great. It I picked the wrong wheels the parking lot ate them up.
Yes it is 3 side slip on with removable plixi glass for bit changes.
Kyle Stapleton
Desktop w/spindle
Potter Pen
How did people like the Desktop?
Any sales? or wrong type Craft Fair?
Were you cutting?
Sold about 25 corian cutting boards in 6 hours.
Used the bot to put in drip trays and v carved names on them so it turned out well.
Handed out a lot of business cards and talked to a lot of people so I hope we will get more business from that.
Kyle Stapleton
Desktop w/spindle
Potter Pen
Sounds like you may not have charged enough
Excellent for a first show.
Did you put any contact info on cutting board itself ?
No did not have time, but might have to add them on the rest.
Kyle Stapleton
Desktop w/spindle
Potter Pen
Use a wedging jig?
You can get pretty small with something like Franklin Gothic Demi Bold and a 45VBit and still be unobtrusive and legible.( Drillman1's on E-Bay little $4 1/8's are great for that, as you can always afford to throw a new sharp one in.)
Yes only moved once.
You have a link? What feed and speeds
Kyle Stapleton
Desktop w/spindle
Potter Pen
Kyle I try to stay with his Kyocera Tycom brand, but bought some of these from 30-90 degree and hard telling the difference. Celtic buttons were done with these in a 90- and just used his 1/8"EM in old dry Rosewood with excellent results. He has an 8 piece set with the full range 30-120 degrees for $40 that looks good for playing.
Haven't cut Corian, but Black Walnut through Bloodwood, .8-1.1, .4-.6, 14-16K at 1/2 diameter passes--Usually duplicate toolpath/edit and then run a 1.6-2.0,1,16K clean up pass if needed(still working on best depth for speed, but .09"pass works good for quality).
http://www.ebay.com/itm/5-45-degree-...item2343cd8a9f
