Sanding Sleeve Slippage
On my oscillating spindle sander i have the cylindrical sanding sleeve with the neoprene sleeve on the shaft of the spindle sander and the everything is new and about halfway into doing a bunch of sanding the neoprene sleeve with the sandpaper stops spinning when wood contacts it. The shaft is spinning the sleeve is just not catching and just stops even with the lightest contact.
I can't tell if it is slipping between the shaft and the neoprene or the neoprene and the sanding sleeve. I have a washer on bottom and top and screwed down tight.
Does anyone have a trick to make the sleeve stick to the shaft better?
Words of Wisdom:
