I have the new upgrade to 4g my problem is I was running it on test run stop it and went to start it in cutting mode it will only move slow and I mean slow only in the x and y axis z axis is fast
Harry, it sounds like this is the first run with the new 4G setup. Have you tried doing a UR to reset and then load the default values for older PRT ShopBots with the 4G upgrade?
